Fan Shroud Removal
Old Jul 19, 2007 | 11:37 PM
Palengke's Avatar
Palengke
Default Fan Shroud Removal
How do one remove the fan shroud on a stock 74 L-48 coupe? I will rebuild the front end with new bushings and he shroud is o the way. Thanks for the input.
Old Jul 19, 2007 | 11:42 PM
vettecrazy88's Avatar
vettecrazy88
I believe that the easiest way is to remove the hood and take the radiator support out as an assembly. Its realy easy that way to replace the shroud and corectly install the seals. I found it to be sooooo much easier that way, especially if you have someone to help with hood and support removal and installation.
On my 75 the A-arms got in the way when I tried to intall the shroud without reoving the hood.
Good luck.
Old Jul 20, 2007 | 12:29 AM
chuck d's Avatar
chuck d
Removing the shroud is a PITA. I had mine out recently for a radiator replacement. In hind sight , removing or looseing the support sounds like a good idea. I have ac so I elected not to go that route. Luckily a previous owner had modified the shroud so it would come out more easily. It was still tough, even with the modifications.
Old Jul 20, 2007 | 12:31 AM
Oldguard 7's Avatar
Oldguard 7
I have a 79 and it wasnt too difficult. I removed the fan blade , diaconnected the hoses and unbolted the shroud and snaked it out. Maybe I was lucky.
Old Jul 20, 2007 | 04:33 PM
Ed Blue 03's Avatar
Ed Blue 03
Cut the shroud in half on my 73, came right out.
Old Jul 20, 2007 | 08:23 PM
vette blue's Avatar
vette blue
To remove the upper a arms on both sides you do not have to remove the rad shroud. You can simply tap out the studs which are holding the upper a arm shaft. Mine came out very easily and only needed to be removed on the passenger side.
Old Jul 20, 2007 | 10:31 PM
Star79's Avatar
Star79
me too
Old Jul 20, 2007 | 10:47 PM
mrvette's Avatar
mrvette
YUp, you cut it about 1/2 way up, across each side....then take some aluminum to make a kinds sandwhich with the bottom lip, leaving a slot for the top 1/2 to slide into...4 screws/nuts it's done....then you can pop the top off at will, and get to whatever you need SO much faster....
been doing that for years with various cars...old trick...
Course you go the Dual Spal route, and you can kiss that damn shroud good assed freeking BY forever.....
Old Jul 21, 2007 | 01:49 AM
Vesa's Avatar
Vesa
Even better to dump it while you are at there and buy 1-2 electric fans
To Fan Shroud Removal
