BarryK.........Please excuse me if I'm wrong, but in 1970 GM did not put an AIR system on the L46 (350/350.) Right?
As part of my new heater core project, I'm going to replace the thermostat. Because of your (and Young69Owner) suggestion, I’ll put in a 180 degree stat. Thanks.
I'm not 100% sure about the AIR in your '70 but they started putting AIR on in '67 on some cars so I assumed by '70 it was on them all. I very well may be wrong.
Regardless, it sounds like you don't have it on your car so I'd run the 180º t-stat
80crabvette.......It's my understanding (from my C5 & C6 friends) that a cooler engine makes more HP. The negative of a low temp t-stat is higher emissions, greater likelihood of sludge development, and plug fouling.
Way back in my college years, my girl friend had a Ford that continued to run for thirty seconds after the car was turned off. Well, remembering back to my auto mechanics classes in high school, I replaced the t-stat with a 170 degree one and all the dieseling problems were gone.
assuming the cooling system was effective enough to keep max operating temps at t-stat temp (not likely in most cases) than a 160º operating temp is too low and will not allow the motor to have a high enough operating temp to burn off excess vapors causing condensation and sludge in the oil and motor.
