headers in general..
Old Nov 1, 2001 | 09:00 AM
mrvette's Avatar
mrvette
Default headers in general..
Few questions here, I have a set of mr Gasket headers, unknown anything else, except full length....so question is, they will not work with the rack/pinion setup on the driver's side...need modifications.....
so....am I better off just getting another set??? any thing anyoe runs that is closer to the block??? thinking of shorty block huggers if it's any losses over the full length things I have now...???
OH the tubes are 1 5/8 od... it's a 355 engine...injected '72 engine, edelbrock heads,but may go back to iron...
can the headers be modified??? what is the usual cost???
GENE
Old Nov 1, 2001 | 09:15 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: headers in general.. (mrvette)
Gene
If you can weld you can modify the headers. I doubt that you will find anyone to do it for you except maybe a buddy...
All you need is a hacksaw and your favorite welder...
You buy the tubing bent into a U and then cut slpice and weld the pipe back together.
Dons Hot Rod Shop has the best prices on U bends
1-800-888-8892
