My 1974 BB draws only about 8 inches of vacum at 6oo rpm. I have learned from different places that it could be late valve timing and that it takes a lot of work to correct. What exactly is "late valve timing" and how do I check it and how to fix it?
From: Graceland in a Not Correctly Restored Stingray
By late valve timing, that refers to the intake valve closing event occuring after the optimum point. Generally, the later in the combustion stroke it closes the less vacuum "signal" you'll have in the intake at idle. Another adverse effect of late timing is the loss of dynamic compression, as the engine cannot begin to build compression until the intake valve is shut.
Sounds like you may need to advance the cam, as it should help not only idle vacuum, but could wake up some hidden performance. However, I wouldn't do it arbitrarily without doing some homework first.
Thanks for your reply
Yes I will try to do my homework before starting anything, but my problem is that I have no ide how to check my valve timing and nor do I know how to eventually correct it. Any help would be appreciated.
Assuming your engine has the stock cam, it's relatively easy to find out your valve timing specs. Of particular interest are lobe seperation angle and intake centerline angle.
Next, look for information on how to degree a cam. This will help you determine where your cam is indexed and will reveal the timing of the intake valve closing event. (If your cam isn't stock, and you can't find the cam card to your stick, understanding this can help you graph your specs.) You'll need a piston stop, degree wheel and dial indicator, all available thru any good speed shop, to do this.
Should you not wish to go thru the trouble to remove the front cover before you commit to adjusting the cam, it may be possible to improvise with a fully degreed timing tape on your balancer, but it won't be as accurate as using a degree wheel.
Once that's established you'll be able to judge, with a little good advice, whether or not to change things. If so, you'll need a timing chain set with provisions to adjust timing. They are also available at any good speed shop, Cloyes being one of the brands to look for.
Hope that gives you some insight. If you know which end of a screwdriver to bang on, you can do it.
I never heard about a timing chain set with provisions to adjust timing before.
Is it so to understand that the cam has come out of adjustment? How can this happen?
I have uploaded a videorecording of my vacumreading on youtube, this is done with all the vacumlines disconnected wich gave me a little higher reading, about 10 inches at 600-700 rpm. If you bother to take a look at it it would be nice since it don't tell me more than it's not perfect.
The quality is not so good, was difficult to get a good footage of the gauge in the sun, but the red lines on the gauge is at 10 and 14 inch of mercury. Each line has 2 inch of increment. You can see it idling at about 12 and dropping to 10.
Remember this is with all vacumlines disconnected and plugged.
Thank you
If your timing chain stretches, the cam timing will be retarded. This will have a negative effect on idle vacuum, low end power, throttle response & fuel milage. It sounds like you might also have a vacuum leak. If you have a distributor with vacuum advance, make sure you check the diaphram for leaks.
So it's maybe a timing chain problem I have. Is there a easy way to check if that is the issue?
Also I have checked the diaphram and it's solid with no leaks, but with my Mityvac pump i found that I have leaks in different hoses and that will be taken care of.
If you look at the video recording you will see how it function with all vacuum lines disconnected and plugged.
I watched your video. It sounds like somebody has installed a more radical cam.
The more radical the cam, the higher the idle rpm needs to be.
To increase vacuum you have to use a higher initial spark timing. Like 14- 18 degrees with the vacuum advance disconnected. Then you have to adjust the idle mixture screws to get the smoothest idle.
I have also been thinking about that someone has done that . Is there a way to find out about that without disassembling the engine?
The timing is a little above the area you describe. It was set at 40 degrees when I bought it, but I have retardet it to about 20.
The weights in the distributor is not working at all so I have ordered new ones. Hope it will help.
This is an example of how to measure the cam, but instead of tearing the motor down you can just place the dial indicater point on the push rod end of the rocker
Thank you, that was very informative.
How about the timing chain, if this is worn out can this set the cam enought out of position so it will affect the vacum?
You have already stated that the distributer was not functioning........
It is best to attack the problem with the easy things first. Like enshuring correct spark timing and tune of the fuel system.
Actually most cam grinders grind 4 degrees of advance into their American V-8 cams. The reason is to allow for chain stretch. So the 4 degree ground in only lasts for the begining part of the motors life.
I have my cams ground without the 4 degrees advance and I use quality billet steel cam timing sets that don't stretch like the cheap timing sets.
You have a big duration cam that is never going to have lots of vacuum. Once you get everything else running up to 100% and you think you need vacuum the fix options are. Install a vacuum reserve canister, buy a vacuum electric or belt driven pump, change to a milder duration cam.
I did forget one thing. If the motor is old and warn out then look at a rebuild with a new timing chain
The distributor will be taken care of as soon I get my parts.
Regarding the vacuum it is not a problem since everything works on the car with the amount of vacuum I have, it only bothers me because it's is not like it should be and I was looking for opnions on what it could cause. I've learned a lot out of your postings and I'm very thankfull for that.
So I think it is like you stated, a big cam in it
