I recently purchased a 1974 Vette. Someone for an inexplicable reason had graphted an early 1980's front & rear clip and bumpers onto it. I am going to remove the front & rear clip and bumpers, and doors before I try and lift the body off. My question is how to select a lifting device for the weight of the body. Any estimates of what the body would weight? I have an engine lift with a 2 ton capacity, however I do not know if it has the reach to center over the body for lifting and get the height to clear the frame. Any help with a weight estimate would be appreciated.
Straps is how most do it. I've seen pictures here of guys using engine lifts to lift the body. I'd do and archive search and you'll find tons of info. I't much easier if you have an overhead beam and winch with lots of clearence.
Straps are sold by a few of our vendors or go to the parts section and post a WTB Body Lift Straps thread. New, they are around $100, used, around half. You may want to pick up the "how to" video too...good luck...gp http://s187.photobucket.com/albums/x...t=DSC03899.jpg
I just did this. Straps to the bird cage rails and an engine hoist works just fine.
The body doesn't weight that much. With the doors off and interior out, I can lift one side of the body off of the wooden dolly by hand without significant effort.
BTW, the body shop will be putting the body back on for me. I was just about to put my Eckler's body strap and Noland body lift video on e-bay. If you're interested, send my a PM. Thanks.
Your pic looks like it has the same type of lift as I do. Thank you for the quick shot. I appreciate all the replies & links from you all! Looks like a lot of fun! I will remeber to make sure the nose is off too!
