Help with lower radiator support. on 80
Old Jul 23, 2007 | 06:43 AM
joefloyd's Avatar
joefloyd
Default Help with lower radiator support. on 80
Can some one help me with the procedure for removing and replacing the lower radiator support on an 80 Vet.
Thanks Joe.
Old Jul 23, 2007 | 07:03 AM
SIXFOOTER's Avatar
SIXFOOTER
Remove hood, radiator, shroud. then there should be 3 bolts on each side, 1 thru the frame and 2 more thru the fender skirt. Remove the vac can support.
I think it will come out then, sounds simple, but its a lot or work
Old Jul 23, 2007 | 07:10 AM
windup's Avatar
windup
You might want to remove the fan aswell.
Old Jul 23, 2007 | 07:11 AM
BarryK's Avatar
BarryK
yep, that's about it. And like he said, it's not hard but plan on a few hours getting it all done.
also, I'll STRONGLY suggest that if you are pulling the radiator core support out of the car that you use something to prop up the nose of the car while the support is out. The core support helps support the nose and while it's out the nose can droop on you
Old Jul 23, 2007 | 07:14 AM
joefloyd's Avatar
joefloyd
Thank you for the info. I thought that there was more than the 3 bolts on each side that I can see. Are the other 2 bolts the hard ones to ge out?
Old Jul 23, 2007 | 07:18 AM
joefloyd's Avatar
joefloyd
Where is the best place to support the nose?
Old Jul 23, 2007 | 08:15 AM
SIXFOOTER's Avatar
SIXFOOTER
Actually the bottom bolt is the tough one to get out, it is in between the frame and outter bumper support. To support the nose, If you have something overhead to attach to, run a strap around and under the nose in front of the wheels and just put it snug, it is to hold, not lift. If not, Stack some blocks under both sides so that they take the weight of the nose that is normally helb by the rad core support
Old Jul 23, 2007 | 08:37 AM
joefloyd's Avatar
joefloyd
I noticed that the fenders and the hood are sitting higher then the top of the doors. Can this be caused by the front of the nose not being supported properly by the bad radiator support?
Old Jul 23, 2007 | 10:39 AM
Artsvette73's Avatar
Artsvette73
How does the gap between the door and fender look? Yes it can be caused by
Not being supported properly
Rusted out suppport
Pervious accident damage
To Help with lower radiator support. on 80
