Question About Rivet Bubbles on Hood
Old Jul 23, 2007 | 02:30 PM
ritaylorz06's Avatar
ritaylorz06
Default Question About Rivet Bubbles on Hood
Can anyone tell me the cause of the rivet bubbles on the hood above the head lights on many C3s that I see? Did they come this way from the factory?
Old Jul 23, 2007 | 02:37 PM
Solid LT1's Avatar
Solid LT1
The metal panel that the headlght gear bolts to is riveted to the bonding strip and then glassed into the front surround. Corrosion of the riviets makes the area expand and the rivet bubbles you see appear above the headlights. Fix is to remove rivets although you can grind down the area and finish it for a quick fix(3-5 year fix.) If you grind down area, and get at bracket from below and attack the corosion by blasting and priming it, the fix will last a lot longer than just attacking the top area.
Old Jul 23, 2007 | 03:11 PM
PNK's Avatar
PNK
If i remember correctly the rivets are made of aluminum and the crossmember is of steel the 2 materials dont mix well, we did drill out all the rivets on a friends 69 and replaced the rivets with SS ones, it's been 4years now and no sign of any problems
Old Jul 23, 2007 | 04:07 PM
Stewart's74's Avatar
Stewart's74
actually, the rivets are not needed anymore. 3M makes a product that will bond the metal headlight surround directly to the underside fiberglass. late Model C3's did not have the rivets either.
Old Jul 23, 2007 | 05:40 PM
ritaylorz06
Thanks for mthe info.
Old Jul 23, 2007 | 05:43 PM
Schwee's Avatar
Schwee
I guess my '81 is not a late enough model. I have the rivits and plan to drill them out and replace with the glue.
Old Jul 23, 2007 | 05:45 PM
big_G's Avatar
big_G
If you have rivets G.M. didn't put them there.....
To Question About Rivet Bubbles on Hood
