Astro-Ventilation Question
Old Jul 23, 2007 | 11:01 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Astro-Ventilation Question
About two weeks ago, I purchased a '70 L-46 no a/c Corvette. It seems like no matter how I adjust the ventilation, it just blows hot air. The heater core has been replaced and all the "pluming" is correct. Is this normal or is there a trick to get the system to blow non-heated air?
Old Jul 23, 2007 | 11:41 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Common problem. The air in the plenum from where the Astro-Ventilation sources, is good and warm from the engine, exhaust, and tranny.
Not sure there's a fix for non-air cars. Many completely block off the vent(s) behind the kick panels where a lot of heat comes. And there are different ideas about further insulating the ****-pit but that's not the problem you're tackling.
But I don't understand why Vettes suffer heat more than other cars with the same system. Perhaps less room under the hood,..don't know.
Old Jul 24, 2007 | 10:31 AM
PETKAH's Avatar
PETKAH
I have a '70 that was originally air but the guy before me took all the
AC parts off. I have done most of what has been recommended - insulate under carpet, put a valve on heater hoses so hot water doesn't
come into the heater core, and many more. But, my '70 is souped and
runs great but after an hour of driving my steering column is hot to the
touch as are the bezels. Vettes are "hot" in many ways!
Old Jul 24, 2007 | 10:35 AM
gavanm01's Avatar
gavanm01
Don't feel bad--even those of us with the a/c working well have warm cockpits. I mounted sidepipes and that did seem to dissapate some of the heat but the other guy's right, the Vette's just a hot car.
Old Jul 24, 2007 | 10:49 AM
dobroman2001's Avatar
dobroman2001
I had heat coming in from the vents as well. When the engine got up in Temp I could really feel in pouring in. I saw where another member had used something called "Refletix" to insulate his car (under the carpet). I had planned on using that so I went to the local "Lowes Hardware Store" and bought a roll... something like $22.00. I cut a piece of that and wrapped the box in the engine that houses the fan unit (my car is a A/C car). That fixed the heat coming in issue for me!!! I assume that the air being sucked into that box from the cowl was being warmed up because the box has no insulation..... Anyway, whatever it was I now have no more heat coming in when the setting is on VENT.
With the setting on MAX A/C I still have heat but I suspect that reason is because I have no insulator down in the car and no carpet as well.
Below is another Link where PhotoVette discusses something similar...
http://forums.corvetteforum.com/show....php?t=1715489
Good Luck,
Old Jul 24, 2007 | 11:57 AM
doug_dayson's Avatar
doug_dayson
Check:
a) That the Blend Door Cable is properly adjusted and actually turning off the heat.
b) The Hood Seal at the cowl end of the hood is critical, make sure it's there and sealing, otherwise engine heat goes right down the plenum.
c) All HVAC seals etc.
For those with AC cars a good mod is a Compressor Clutch on/off switch. This allows you to use the AC Normal path without the Compressor Clutch activated for fresh air flow (much better than the Vent path).
Old Jul 24, 2007 | 12:23 PM
Cosmo Kramer
Everybody...........Thanks for your replies and suggestions. The great thing about this forum is we can all learn from each other.
As part of my light restoration process, I'm going to replace the carpet. Well, as long as I'm in there, I plan on putting down some of that heat reflective stuff that Corvette Central sells. Hopefully, this will help cool down the **** pit.
PETKAH..........Great suggestion about the shut off valves to the heater core. Is it necessary to put shut off valves on both hoses or is just one sufficient?
Old Jul 24, 2007 | 12:50 PM
PETKAH's Avatar
PETKAH
I have a shut off valve in each hose although I've seem some with just
one. (Use the search function and you will get great details on how to
do.) I also have side pipes because I like the look & sound. (You can
get a bolt on kit for about $900 with fiberglass covers like I have - you
won't get burns.) Other reasons why hot -- cast iron manifold, needs
a double firewall, more tranny tunnel insulation, and needs to have cool
air come in from the front of the engine - not behind. OK - the real reason it's hot - and I'm trying to say this carefully so I don't get Forum
Flamed - In my daily driver I have a 3.2 - now, if you compare this to
a stock Vette it would be about 7.2. Is the engine too big for the car -
of course not it's too much fun to drive.
Old Jul 24, 2007 | 03:30 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by doug_dayson
Check:
Especially the adjustment of the air distribution door.
Check this thread out for some ideas.
http://home.comcast.net/~chadwick.ro...entilation.htm
To Astro-Ventilation Question
