where the triangular shaped foam insulation pieces belong. I took them out so long ago I can't remember the exact location. The AIM isn't very specific & nothing is making sense at the moment. I know they belong against the toe board along the frame.
Jim
Reason: bad description - oops
Oops helps to read what you type :o The little foam insulation pieces at the front of the frame/firewall area.
Jim
My 79 had triangular foam pieces, they fit between the fender and the steel inner reinforcement right at the side of the front support of the firewall (between the support and the fender.
However I believe a 70 had different type of insulators...
I think this is it
Look right to you guys? This is the original made in white foam
