Spring in lower radiator hose?
Old Jul 24, 2007 | 08:32 PM
johnwhoss's Avatar
johnwhoss
Default Spring in lower radiator hose?
I've seen it mentioned here that the lower radiator hose should have a spring in it to prevent collapse. Is this true for a '77 L-48? I felt around in mine and could not feel one. Another suspect causing the car to run hot on the freeway?
Old Jul 24, 2007 | 08:49 PM
chuck d's Avatar
chuck d
My 73 L-48 car has a spring in the lower radiator hose. I had to transfer the spring to the new hose when I replaced it. Without the spring it could be colapsing, causing an overheating problem.
Old Jul 24, 2007 | 08:52 PM
vette blue's Avatar
vette blue
My 71 has it as well and serves to prevent the collapse of your hose thus preventing overheating. Most of the Vette suppliers should carry it.
Old Jul 24, 2007 | 09:32 PM
johnwhoss's Avatar
johnwhoss
I just did a quick search of the larger parts suppliers and they all carry GM lower radiator hoses but there is no mention of a spring. Is it assumed that they all have a spring? Does the spring run the length of the hose or just in the bend? I'm squeezing the hose but I can't feel a spring, would I be able to?
Thanks!
Old Jul 24, 2007 | 09:59 PM
vette blue's Avatar
vette blue
You'd definitely feel it. Mine runs right through from top to bottom. Try calling the vendors it may already come included with the hose?
Old Jul 24, 2007 | 10:43 PM
johnwhoss's Avatar
johnwhoss
I did more searching and went to Paragon's web site. They have a more detailed description of their radiator hoses. In their descriptions of lower radiator hoses, they specifically say whether the hoses have the spring, but not for the Late '76-82 hose. Did the '76L-'82 lower hose originally have a spring? I noticed in the pictures that the '76L-'82 design was a little straighter than the other years. Maybe the '76L-'82 lower radiator hose was designed so a spring wasn't necessary????
Old Jul 24, 2007 | 11:41 PM
bytor's Avatar
bytor
I had problems finding one with a spring installed also. The straight universal hose that most auto parts store have on hand has the spring in it. I bought one of these and removed the spring from it and installed it in a new molded lower hose.
To Spring in lower radiator hose?
