Vac advance
Watch out that you don't end up with too much vacuum advance. I ran into this yesterday.
I set my total timing at 36 but with vacuum I was at 60, way too much.
I am custom building a limiter so i can fine tune the total advance.
I want 50 -52 degrees total of all 3
I just went through this and found an Echlin VC1862 AR31 (NAPA)can has 8 distributer degrees,(16 crank) and pulls fully with only 8 inches a vacuum. This with a 36 degree mechanical gives 52 degrees. So far no pinging,but with the hot weather in the afternoon,I think it's pretty close. In the morning with cool air this curve rocks. Throttle response is explosive off idle,and at cruise speed it just sails along effortlessly.
I tried a homemade limiter myself at first(limited about 4 degrees) and it felt like it was holding back some while cruising at 60-65 mph.
as for what level to set your adjustable unit at, first check to see what vacuum level your motor is producing at idle and set the vacuum advance to come in at approx 2" hg below that.
The bottom line is vacuum advance virtually always improves throttle response, gas mileage and makes the engine run cooler (due to less transfer of combustion heat to the head as a result of the increased advance) on a street car, period. This assumes of course that you follow the guidelines others have given here which is right on (approximately 36 degrees mechanical and the rest vacuum to a total of no more than 52 degrees). Good luck
The car ran like crap each time when they returned the car to me.
My neighbor found what they did and removed it and the next mechanic would do the same thing.
That'shen I realized that if I wanted to have my older vette with points ignition system, vacuum advance, and carb run correctly that I needed to start to learn to do things myself.
The vacuum advance system is widely misunderstood, even by so-called "professional" mechanics.
Yes, you can run the car without it but on a street driven car it's important and greatly helps the car run better in terms of idle characterics, throttle response, fuel ecomony, and lower operating temps.
Boats and race cars don't need it as they are typically run WOT most of the time but street cars run at varying loads constantly and it's the vacuum system that adjusts timing based on load.
Truth is if you run it then set the rest of the car up with it that way but don't go changing idle and timing everyday or it all will be messed up.
If your car has full time vacuum and the timing is set with it, then if you unplug it the car won't idle, if you don't use vacuum then the car will idel high if you plug in up to vacuum.
Pick your poison and drink it!!!
That was a typo I meant 11 initial, 36 total.
All you Warren Johnson wanabe's read and learn
Not having full vacuum advance at idle (timing retarded from where it should be at idle) increases exhaust gas temperature, which heats the coolant more, driving up temperature at idle; this was the factory design "ported spark" condition in the 60's with air-injection systems to ensure a good "afterburn" in the exhaust manifolds when the injected air hit the exhaust stream at idle, which was where emissions testing was done in those days.
Most of those "ported-spark" cars had factory base timing at 0 degrees (some were actually 2-4 degrees AFTER TDC), and had 30-34 degrees of centrifugal advance in the distributor to try and make up for it. Cars with full manifold vacuum on the distributor at idle had factory base timing set at 8-12 degrees, and their distributors had 20-26 degrees of centrifugal advance. Same WOT total timing for both, but the "ported spark" engines with air injection systems and retarded idle timing ran like crap at idle and part-throttle, and ran hot at idle.
Properly-matched vacuum advance can calibration (so it's fully-deployed at idle) with manifold vacuum makes for stable idle and a cooler engine at idle, better part-throttle driveability and throttle response, and improved fuel economy.
If you had a timing light rigged so you could see it cruising down the highway at 50-60mph with vacuum advance, you'd see 50-52 degrees advance at highway cruise; the lean cruise mixture takes longer to burn than a rich mixture, so the vacuum advance "lights the fire" sooner so maximum cylinder pressure is still reached just past TDC for peak fuel efficiency. When you accelerate, the mixture is instantly richer and takes less time to burn, so the vacuum advance drops off, retarding the timing slightly to accommodate the faster burn time, again maintaining peak fuel efficiency.
Without vacuum advance (just centrifugal), timing is only affected by rpm, not engine load (manifold vacuum), so optimum torque isn't reached and timing isn't optimized for engine load and mixture burn rate. Vacuum advance is useless on a race engine that is run at WOT all the time, but it's essential for a good-running street engine that has to run at idle and part-throttle too.
People that run fancy chrome-and-polished whizbang centrifugal-only distributors on a street engine have been suckered by the Summit/Jeg's race-car marketing hype, and are missing out on the joys of a really good-running street combination. Absolutely. Positively.
If you had a timing light rigged so you could see it cruising down the highway at 50-60mph with vacuum advance, you'd see 50-52 degrees advance at highway cruise; the lean cruise mixture takes longer to burn than a rich mixture, so the vacuum advance "lights the fire" sooner so maximum cylinder pressure is still reached just past TDC for peak fuel efficiency. When you accelerate, the mixture is instantly richer and takes less time to burn, so the vacuum advance drops off, retarding the timing slightly to accommodate the faster burn time, again maintaining peak fuel efficiency. This is incorrect. The vacuum advance feature is there to compensate for differing burn rates due to cylinder density (pressure), not fuel mixtures. Your A/F ratio should not bounce around so much that there needs to be great changes in the timing. Fuel related spark trim is a minor secondary issue compared to the timing adjustments required due to the wide range of load/density pressures that the cylinders see.
People that run fancy chrome-and-polished whizbang centrifugal-only distributors on a street engine have been suckered by the Summit/Jeg's race-car marketing hype, and are missing out on the joys of a really good-running street combination. Absolutely. Positively.[/I]
