'70 L46 Cutting Out.
Old Jul 27, 2007 | 11:13 AM
Cosmo Kramer's Avatar
Cosmo Kramer
Default '70 L46 Cutting Out.
Under heavy acceleration and at high RPMs (>4K,) the engine seem to "cut out" or misfire. My mechanic says it's due to the carburetor - he's suggesting a carb. rebuild. To me, cutting out is an electrical problem. He's already replaced the distributor cap, rotor, points and spark plug wires. So, do you think a carb. rebuild will cure the "cut out" issue?
Old Jul 27, 2007 | 11:29 AM
Artsvette73's Avatar
Artsvette73
The can be a fuel starvation. Could be fuel pump pressure, Or fuel filter needs to be changed
Old Jul 27, 2007 | 11:57 AM
Trae1976's Avatar
Trae1976
Does it backfire as well?
I recently had a similar condition - replacing the ignition coil resolved the problem.
Good luck
Old Jul 27, 2007 | 01:43 PM
Matt Gruber's Avatar
Matt Gruber
1st i'd lock the choke wide open. test drive.
then look at the plugs.
Old Jul 27, 2007 | 01:55 PM
427-390's Avatar
427-390
What is your total timing set at? Should be 36* @ 2800 - 3000 RPM with the vacuum advance disconnected. Start with your timing first, and work you way out from there.
Old Jul 27, 2007 | 11:58 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Sounds like a fuel supply problem to me. I'd change the fuel filter(s) first. Also, has the strainer in the tank ever been replaced? Do you have a crimp in a hard-line somewhere.
Other possibilities include malfunctioning mechanical advance (rust and crud can prevent the weights from opening properly),..or crummy fuel,...or broken valve spring(s).
Let us know what transpires and good luck!
Old Jul 28, 2007 | 03:08 PM
CoolKars's Avatar
CoolKars
I had a similar problem on my 70 L-46, it was the fuel hose from pump to tank line. Mechanic used regular fuel line hose, made it too long and at high RPM would closeup. Replaced with the molded S fuel hose and vapor return hose, fixed problem. Good luck tracking down problem.
Old Jul 28, 2007 | 04:05 PM
vettfixr's Avatar
vettfixr
Check the sock in the tank. If it's clogged it will starve the engine at high rpm.
Old Jul 28, 2007 | 08:33 PM
dennis's Avatar
dennis
do you have a 7040207? TCS hooked up? My first check would be the choke is opening fully, and the secondaries are free as well. Timing after that
Old Jul 30, 2007 | 12:39 PM
Cosmo Kramer
Everybody...........Thanks for your replies and suggestions. My mechanic is rebuilding the carb. (Rochester) today. The previous owner removed the "in the carb." fuel filter and replaced it with a spliced in line filter. The mechanic will bring the fuel filter and line back to stock. Hopefully, the rebuild fixes the problem.
Old Jul 30, 2007 | 04:56 PM
mr. creosote's Avatar
mr. creosote
I had a bad resistor someone had put in line with my coil that caused the same type problem. I removed it and checked my timing and it ran great after that.
Old Aug 1, 2007 | 11:38 PM
scotty13's Avatar
scotty13
Tach wire grounding out or finding a hot will cause that..... been there done that....
If the carb isnt the issue, watch the tach next time is does that... Does the needle drop to 0 or spiratically jump?
If so check the wire.... should be the brown one
Old Aug 2, 2007 | 05:10 AM
Matt Gruber
the only way a carb that gets fuel will cut out at 4k+ is if the choke closes
Old Aug 2, 2007 | 09:03 AM
Cosmo Kramer
Well, as it turns out, the carb. was the problem. As mentioned earlier, the previous owner replaced the stock fuel filter with an inline filter that was very restrictive. Additionally, the carb. float bowel were stuck. The combination of the two was causing the carb. to starve the engine at high RPMs.
Aside from fixing the "cutting out" issue, the carb. rebuild fixed a roughness characteristic that I figured was normal for a 37 year old car. Finally, the car feels (as measured by my Butt-O-Meter) MUCH stronger. The gas mileage, however, is still terrible. Perhaps, I need to tighten the loose nut that holds on to the steering wheel ???? Nahhhhhhh!!!!!
Again, thanks for all your suggestions and advice .
Old Aug 2, 2007 | 04:36 PM
FKING1's Avatar
FKING1
My 70 L46 likes every gas station it sees. Mileage is very poor with the 3.70 rear.
Old Aug 2, 2007 | 11:01 PM
Meatburner's Avatar
Meatburner
It's a corvette.....ain't it cool!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 2, 2007 | 11:56 PM
Cosmo Kramer
FKING1.............I, too, have the 3.70 rear. My '05 has a 3.42 rear and gets 29 mpg. The '05, however, has an M6. Technology is wonderful, but nothing can replace tradition!!!!!
Out of curiosity, at 70 mph (according to the inaccurate speedo,) how many RPMs are you turning?
Old Aug 6, 2007 | 04:45 PM
FKING1's Avatar
FKING1
Only drive it occasionally, but I think it is about 3500 RPM at 70.
To '70 L46 Cutting Out.
