rear end leak
Old Jul 27, 2007 | 12:48 PM
sam78's Avatar
sam78
2nd Gear
Default rear end leak
Losing fluid out of the rear end where drive shaft mounts the rear axle. Which rear main seal would be best for a '78 with the L48 motor and automatic tranny? GM no longer sells them and the aftermarket makes several different ones: single vs double lip, silicone vs rubber.
Old Jul 27, 2007 | 11:28 PM
marshrat99's Avatar
marshrat99
This is a great question since I also have the same problem. Once each spring I have to check the rear fluids and add a little lube. My wife gets pizzed with the oil drops in the garage.
Old Jul 28, 2007 | 12:12 PM
GTR1999's Avatar
GTR1999
Sam,
I'll PM you some info to help
To rear end leak
