Body mount measurements
Old Jul 28, 2007 | 05:14 PM
chivic's Avatar
chivic
Default Body mount measurements
Could someone give me the #2 & #3 body mount measurements. I took the cage nuts off to rebuild them and I need to get them back in the right spots. I should have taken the measurements before I took them off but I was on a roll!
Tanks, Chip
Old Jul 28, 2007 | 05:39 PM
Red 69's Avatar
Red 69
I took my #2-3 mounts off the frame so I could spray undercoating inside. I just centered them over the hole in the frame and welded them back in place. Run a bolt down the nut to help center it. Remember, the frame hole is larger in diameter than the bolt, and the caged nut allows wiggle room for mounting the body. Everything went together for me as before taking them off. Never took any measurments, if it offers you any confidence.
Old Jul 28, 2007 | 05:47 PM
shafrs3's Avatar
shafrs3
This might be of some help, it's for a 69-72 though.
File Type: pdf
To Body mount measurements
