Low oil Pressure?
Old Jul 31, 2007 | 12:15 PM
Erics Quick71's Avatar
Erics Quick71
Default Low oil Pressure?
My oil pressure is about 17 on the guage.
All my other vehicles are about 35, right int he middle.
Is this something I should be concerned with?
The oil level is good. And it does not fluctuate when I accelerate or drive. Always 17 .
Anyone?
Old Jul 31, 2007 | 12:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Could be a bad gauge, as pressure should rise and fall with RPM. Really need to verify your actual pressure. If you truly have only 17 psi, there's not enough pressure to overcome the crank's centrifugal force above 1500-1700 RPM to supply the rod bearings...
A little more at idle is fine but, Per Smokey Yunick, you're only looking for about 10 psi per 1000 RPM to achieve proper lubrication (i.e. 40 psi @ 4000 RPM). Much more than that only wastes power, heats up the oil, and wears the pump and related drive unnecessarily.
Old Jul 31, 2007 | 02:17 PM
Bob Onit's Avatar
Bob Onit
I would certainly check it with another gauge and line right at the source on the block
The fact that it does not move with RPM increase leads me to believe its a faulty gauge or a clogged line or both.
My '73 reads about 20# at idle and never goes above 35# or so
I hooked up a Sun professional gauge at the block and saw 30# at idle and around 60# at higher RPM.
I did buy a new gauge and I haven't replaced it yet but I do know that its off and I can rest easy now.
Old Jul 31, 2007 | 02:20 PM
Erics Quick71
when the car is off - should there be any pressure reading?
If not - my guage is shot!
What else is new!!!
Old Jul 31, 2007 | 02:21 PM
Bob Onit's Avatar
Bob Onit
No.
I would address this asap
Any auto parts store will have a cheap manual gauge that you can hook up and see whats going on.
Old Aug 1, 2007 | 10:51 AM
Erics Quick71
Originally Posted by Bob Onit
No.
Seems as though my entire bottom row of guages are not working???
Clock, Oil, Battery
Is there a common thread between the three I can look into?
Fuse? Wires? etc?
Or possibly all broken?
Old Aug 1, 2007 | 11:47 AM
TheSkunkWorks
That's very likely. The gauges reside in a common mount hidden behind the bezel.
Old Aug 1, 2007 | 12:33 PM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Would the use of synthetic oil have any 'bearing' on the pressure at idle or higher rpm?
Old Aug 1, 2007 | 12:46 PM
TheSkunkWorks
Viscosity is the more important factor here. Synthetics tend to flow better when cold, but after warm-up you shouldn't see much difference.
Whatever oil you choose, run the viscosity that puts oil pressure where it should be. If you can't get it there by changing viscosity, then adjusting the relief spring in the pump is the only other choice.
I forgot to mention that high pressure also opens the filter bypass even more, resulting in less filtration.
Old Aug 1, 2007 | 01:19 PM
Bob Onit's Avatar
Bob Onit
Clock, Oil, Battery
Fuse? Wires? etc?
If the oil pressure gauge is stock it is simply a manual gauge which reads oil pressure through a thin tube that runs from the back of the block to the gauge and is not effected by any other gauge or electrical circuit.
To Low oil Pressure?
