Clutch woes
Old Jul 31, 2007 | 02:31 PM
jamesc1123's Avatar
jamesc1123
Default Clutch woes
I can't seem to get my '73 4 spd into gear. The shifter works through the gears just like normal, but when I step on the gas, nothing. It won't even stall out. It was slipping pretty bad last time I drove it. Still most likely the clutch? Thanks
Old Jul 31, 2007 | 03:22 PM
Bob Onit's Avatar
Bob Onit
Is there any freeplay in the pedal?
Is there any adjustment left on the clutch linkage?
Is the driveshaft still there?
Old Jul 31, 2007 | 04:04 PM
jamesc1123's Avatar
jamesc1123
No freeplay. I'm putting it up on a lift tomorrow, so what all should I check after linkage before I start dismantling my car.
Old Jul 31, 2007 | 06:03 PM
stingr69's Avatar
stingr69
No freeplay will cause the clutch to slip and fail.
You want to have the linkage adjusted so the first 1" of pedal pad travel is free play. You can use a tape measure to the floor and press with your fingers to see how far it travels before it gets stiffer and harder to push down any farther without a lot of force.
-Mark.
Old Aug 1, 2007 | 07:11 AM
bashcraft's Avatar
bashcraft
Most likely. These kind of things usually don't heal themself.
Old Aug 1, 2007 | 10:44 AM
CTZR1's Avatar
CTZR1
Its the clutch! Put that muncie on the floor and put a new clutch in that baby! Just did mine a month ago. Been driven 'er ever since
Old Aug 1, 2007 | 06:23 PM
jamesc1123's Avatar
jamesc1123
Thanks for the advice. I had already bought a new one anyways. Unproductive day though, only got so far as taking out the driveshaft. Since you've (CTZR1) already done the job, do you have any pointers or advice? I have the Chilton's and factory service manuals.
To Clutch woes
