Just looking around at upgradinng the stock ignition on my SB 1972 4spd coupe. Read about his in a recent Super Chevy or something like that where they installed this into a 1972 LT-1 and got great results. Curious if anyone on here has tried this kit?
HEI is a great upgrade and most new units have bulletproof reliability. You need to realize that the Pertronix distributor does not have a tach drive, so you would need to convert to a later style electronic tach. The price is in range for HEI distributors with warmed up module and coil. Good quality standard spec HEI's can be purchased for around $125 with some imports selling for under $100.
To do a reliable HEI conversion, you'll need to run a new power wire to the distributor. It will be easier since you have your steering column out (yesterdays thread). You'll find a 12ga pink wire going to the ignition switch in the harness at the base of the column. Splice into that large pink wire with a new piece of 12ga wire, solder and heat shrink the splice, and run it through the firewall to the distributor.
These conversion kits have been discussed quite often and many will agree that the original points are better while others believe in these conversions. The Pertronix kit uses an optical sensor to trigger cylinder firing compared to better ignition designs that use magnetic pick-ups as a trigger (GM HEI & MSD for example). Optical sensors are less reliable and less expensive than magnetic designs.
If your distributor is in good condition and considering the few miles that collector cars accumalate, your points should give you many years of reliable service. You could look into getting your stock distributor rebuilt. These conversion kits do not give any performance advantage, all they offer is a way to eliminate the ignition points maintenance. The downside is, if the Pertronix sensor fails, you are stuck if nobody nearby has the replacement part. Whereas with points, any auto parts has them and the problem can be repaired and you'll be on the way.
HEI or other magnetic pickup distributors are still the best conversion available from a performance and reliability standpoint. Just my opinion.
this is exactly why I posted this and the kinds of answers I need. Ahoover... thank you so much for the info! Great help and seeing how my stock setup runs smooth and fine I will probably leave everything alone for now!
Sully
Pertronix with an "optical" sensor? SINCE WHEN! Pertronix has been using Hall Effect magnetic sensors since I first started using them in the 1970's and I have had great service from these units since then. Make sure you have the points mounting plate properly grounded or you will get erratic operation, misfires from a poor ground path when you do your conversion. Many times I find the wire going from the points plate to the distributor body broken inside of the insulation. You should change this wire for a braidied ground like GM used in the 50's/60's. Go to a electronix store and look for an item called solder wick for desoldering circiut boards, it is the proper style of ground to use during the conversion. I have had excellent results with Pertronix and the Crane set-up might be worth a look-up with it's intregal rev limiter. Junk those points! You can carry them as an emergency spare if the unit should, fail, I have yet to be left stranded by a Pertronix unit.
Your stock upper ignition shielding won't fit with HEI, so you would need to convert to the later '75 parts.
Did excactly this when I switched my '73 to HEI. Only Diff was i used a blue butt splice, which is fine if crimped correctly on both ends, and heat shrunk to keep water out. Car runs great. points are old world technology, though some NCRS would ding me 100 points. I think the original model T had a points ing,, right?
What ground are you talking about? a ground in an HEI dist set up?
I did error on the hall effect sensor not being magnetic. I meant to say it is a different design than the variable reluctor sensor found in an HEI. I am biased towards HEI's bulletproof reliability compared to aftermarket parts and not fully convinced on the reliability of the points eliminator kits, but that is just my opinion. Pertronix consists of an aftermarket semiconductor part (hall effect sensor) which depending on quality control could be prone to failure and the fact that you hear of failures and people carrying spare parts, makes me question the reliability.
