HELP PLEASE - 2 power steering pump questions
straight after I was done the power steering was almost non existent - i noticed as the revs of the engine increased, the power steering evened out & returned to normal - when dropped back down to idle - it would be tough to steer & turn the steering wheel again
Now my front tyres are too wide for my c3 275 I believe (front & back) & this sometimes prevents me from performing a full lock & you can actually see the front of the car levetating when doing a three point turn for example because they are rubbing on something
My concern is that this combined with doing the donuts at full lock definately stuffed up the power steering pump - or as my friend said the valve or seal or something a rather - is this true?
2 QUESTIONS -
1.) Does this sound like it is DEFINATELY the power steering pump & if replaced the problem will be fixed?
Why then does it operate as normal when the revs increase?
2.) Will any power steering pump for a 350 do or does it specifically have to be a 1980 corvette power steering pump?
Any helpful replies/ advice / opinions much appreciated - thanking you
2, I have a ?? out to Jim Shea about the same thing, got to go find it and see if he answered
I took one apart last week, so the rebuild is easy, I'll never pay $90+ for another PS pump for anything
The Q I had for Jim was what is the difference vehicle to vehicle? I know that C3 PS pressure is just under 1000psi and that it is quite a bit higher for other GM cars. I think the difference is the vavle and spring in the pump. But I got to check
I do know that the rebuild kits are for pumps are for 67 to 82 so that should give some indication that they are all similar at least.
