'75 fuel line installation
If there is nothing wrong with your fuel lines I would just leave them alone. The problem area is where the fuel line rises upward just ahead of the rear wheel. If you do have to replace them do a search of previous postings and you may get some good tips.
Good Luck,
Steve
Also some guys are running flexible hose from front to back.
This is on my list of to do items and I have a mini pipe bender and will buy a coil of tubing and make sections as required and join them.
If you can get your car on a ramp it would certainly help with the install.
As there have been numerous posts about this recently it would be great if you were to document your work as you progress and dont forget lots of pics!
Good luck.
I started to replace the fuel lines on my 1973 back in 2002… one thing led to another and I ended up doing a frame-off on the car… be careful what you start!!!
I had heard, and surmised, that I would need to lift the body off of the frame in order to fit the new lines. I did a bit more research and was told that they could be installed (with some difficulty), if you just lifted that side of the body about 3 inches. Unfortunately I never got to find out, as this is when I discovered that 6 of my 8 body mounts were rusted out… hence the frame-off.
The good news is they’re easy to fit with the body off, and the frame-off turned out fabulously…
The lines as shipped are wrapped around a large cylinder, often a wheel rim. Un-bending them should require little more than carefully “un-wrapping” them. When I saw the manner in which they did this, I chose to pick them up at Carlisle, un-bent. As you probably know they’re a bit more than 8 feet when un-bent. I also chose to go with the stainless steel lines as I don’t ever intend to do this job again. The minor difference in price was well worth it.
Before you start cutting lines, I would recommend you look at your body mount bolts and see how difficult it would be to unfasten them. If they appear in pretty good condition, try lifting the body a few inches and see if the lines can’t be installed without cutting them. At the very least you will have more room to maneuver the lines if you do decide you need to cut them.
Good luck… GUSTO
In fact if your body mounts need new busings, etc. it would be a good time to do both since you've got to undo them anyway.
As for the condition of my lines, they look fantastic on the outside. The problem is I suspect my fuel line (return) to be rusting from the inside out (the previous owner let it sit a lot with water in the tank and I had mysterious flakes of rust in my tank that is not making it the pump and the tank is in excellent shape (dropped and cleaned that two weekends ago)). I was never able to determine if the if the rust was from a bad fuel station.
So here is my solution: Rebolt the fuel lines (I managed to reach each bolt except for one just ahead of the x-member), put a fresh amount of good fuel in the tank, get the car running and use the car as my daily driver for a week. Then I can check the tank as well as the new in-line fuel filter and in-carb filter and syphon a sample out to see if the rust appears. If not, I will forget the fuel lines and assume it was bad gas. If it does, I might look into braided SS lines. I plan on running an LSx in this car eventually, so the braided SS would look good.
If anyone sees a flaw in my plan let me know. I am knew to all of this. I have been a auto fan for years. Heck, I studied IC engines, vehicle dynamics and a slue of others in engineering college but this is my first real wrench turning project involving a car. Please have patience for the book worm! Thanks again guys; always a pleasure.
Let me see if I can assist you a bit. Here's what I did. The fuel lines that come from the front of the car are fairly easy to install until you come to the part of the frame just ahead of the rear wheel. This is the point that I cut the lines. At this point of the frame is a large gusset that ties the right side frame rail and the rear crossmember. This is where I connected the two lines together with a quality fuel hose made of rubber. If you do it right you can hide the rubber part of the lines in the gusset pocket. Make sure after you cut the lines that the ends have no sharp edges or burrs that will cut into the rubber hoses due to flexing or vibration. Also I used double clamps on each side of the hoses for extra insurance. I hope this will be of some help to you. By the way, I am the original owner of my 75 and it is in backyard buddys ad. If there is anything I can help you with just let me know.
Good Luck
Steve
If you can, blow each line out with compressed air. Have someone hold a clean white rag on the other end to catch what comes out. This ought to help indicate any rusting insidfe the line. Have the person holding the rag wear gloves, HP air can tear flesh.
I believe your 75 still used a sock on the sender inlet, inside the tank. This will filter any rust flakes that may appear, and if small ones get through, there should be an inline fuel filter to catch them and one inside the Q-jet as a back-up filter. If your fuel line is solid and functioning, there is nothing better than steel, so leave it alone IMO. As a last resort you can always replace it with a braded line, but it won't be better.
