Power Door Lock Help
Old Aug 2, 2007 | 02:53 PM
81VETT's Avatar
81VETT
6th Gear
Default Power Door Lock Help
I am new to the Forum and need assiatance. Power locks on my 81 Corvette will lock both doors from drivers side, but will not unlock from drivers side or lock or unlock from passenger side. Please advise.
Old Aug 2, 2007 | 02:59 PM
SIXFOOTER's Avatar
SIXFOOTER
First thing to do is check the contacts on the back of the switches. That requires removing the door panels. Open them up and you will probably find loose, bad or corroded contacts on the back of the switch. This might require new pigtails for the switches, not a real bad job
This may help you see how it works
Old Aug 2, 2007 | 04:15 PM
GT1981's Avatar
GT1981
Default re: power door locks
Good advice on the first step.
The second step (while you have the door panels off) would be to check the mechanical operation of the door-locking hardware. My '81 had badly gummed up moving parts. I thoroughly cleaned and lubricated all the moving parts. That fixed my problem; luckily my lock switches were in good shape.
Enjoy your new hobby...
Old Aug 7, 2007 | 10:12 AM
81VETT's Avatar
81VETT
6th Gear
Sixfooter,
Thanks for the assist on power door lock problem. Removed door panels, cleaned connector and and switch terminals. Works great!! Rewrapped harness for good measure. Also took advice from forum member GT1981 and cleaned and lubed all lock hardware, window regulator and door latch wear points.
Thanks, 81VETT
Old Aug 7, 2007 | 11:09 AM
SIXFOOTER's Avatar
SIXFOOTER
Good deal, glad to help. The contacts in the connector are pretty cheesy, but cleaned, adjusted and coated with a little no-ox and they work ok
Old Sep 23, 2007 | 11:15 AM
jcurrie's Avatar
jcurrie
Default Door Looks and Anti-theft
Sixfooter - Where did you get the wiring diagram that you posted? Do they have them available for 1979. I am going crazy trying to figure out how the Power door locks and anti-theft system are interconnected.
Thank you John Currie
jcurrie@ajaxtocco.com
Old Sep 23, 2007 | 12:16 PM
SIXFOOTER's Avatar
SIXFOOTER
81 GM Shop Manual ST-364-81
Here is the alarm stuff
To Power Door Lock Help
