Spark plugs?
Old Aug 3, 2007 | 12:42 PM
agent kronus's Avatar
agent kronus
Default Spark plugs?
ive got a 78 vette, L48, could have modded clylinder head tho
what spark plugs should I use in the L48?
Ive been told NGK - BPR4FS is this correct?
and also what gap should i have??
cheers
dave
Old Aug 3, 2007 | 01:50 PM
BKarol's Avatar
BKarol
In a normal L48
acdelco R45TS
gap .045
same for an L82.
Old Aug 3, 2007 | 03:47 PM
agent kronus
would i use the same gap on the ngk plugs?
Old Aug 4, 2007 | 12:59 PM
agent kronus
what happens if u stick NGK's in at a pre gapped 1.5 which is double 0.6??, ive put them in with the bigger gap, seems to be running fine!. its stopped my poping and bangs in the zorst!, wider the gap leads to more power?? any probs running wider gap?
Old Aug 4, 2007 | 01:21 PM
crazywelder's Avatar
crazywelder
Your gap width is determined by the ignition coil you are using. If you are using a stock coil, gap the plugs at .035". Higher output coils will allow you to open the gap wider. However, a wider gap with a stock coil will put more load on the coil and most likely shorten the coil life since the coil needs to work harder to jump the wider gap.
To Spark plugs?
