Best engine for a 79'
Old Aug 3, 2007 | 12:44 PM
max1986weber's Avatar
max1986weber
Default Best engine for a 79'
Im about to replace the stock 350 in my 79' corvette. I was wanting some opinions on what engine I should put in. What is the absolute best engine that I could put on her. Thankyou.
Old Aug 3, 2007 | 02:04 PM
my mach 5's Avatar
my mach 5
That's a pretty wide open question depending upon what you want to do with the car (street car or track car) and how much $$ you want to spend.
Personally, I went with the GM 350 HO (330 HP) crate engine. It was the best balance of performance and $$ for a street car I wanted at the time.
Old Aug 3, 2007 | 02:09 PM
weimer20's Avatar
weimer20
You'll need to give some more info as to what you want to accomplish with the new engine or you will get as many different answers on this one as there are people. I'd go 572 crate if I could afford to shell out the dough for one. Shoot, maybe built on a custom aluminum block too!
Old Aug 3, 2007 | 02:14 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Or maybe one of these;
http://www.ultrastreet.net/632_1000_bd.asp
Old Aug 3, 2007 | 02:32 PM
weimer20's Avatar
weimer20
Originally Posted by Dell Boy
Good GOD MAN!!! That's a beautiful thing!
Old Aug 3, 2007 | 02:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why not rebuild what you have and keep her stock? If you choose not to rebuilt it, my advice would be to hang on to the original 350 for future sale purposes. A potential buyer might want it.
Old Aug 3, 2007 | 02:59 PM
Glensgages's Avatar
Glensgages
a Chrysler 426-style Hemi-headed, fuel-injected & supercharged Nitro-burning fire-breather!
.....as-stated by other Forum-members, please supply what your intended-uses for this car would-be, so we can better help you spend your money!
Old Aug 3, 2007 | 05:20 PM
worship79's Avatar
worship79
Whatever you do, don't throw in the cheap-*** Goodwrench the previous owner put in mine. He bought the cheapest version he could find: it's rock-solid and plenty reliable true enough, but you might want a little more then 150hp and 285Nm on the rear wheels...
Old Aug 3, 2007 | 05:40 PM
groovyjay's Avatar
groovyjay
The new LS7
Old Aug 3, 2007 | 05:55 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
A 632, bigger is best, otherwise a good 396 or 408 SBC is in order. Don't buy into the 'keep the old stock motor', it's a 79 for goodness sake. Not dissing 79s as I have one, but it's not a chrome bumper car.
Old Aug 3, 2007 | 07:00 PM
Jims79's Avatar
Jims79
by the time you blueprint & bore out then rebuild yhe old L48 your not going to save any money or get the HP's your looking for. & its not going to be a numbers matching vette anymore. So that being said I would go 383 stroker, ZZ4 or LS motor. Much better upgrade more horse power.
Old Aug 3, 2007 | 07:25 PM
Binnie77's Avatar
Binnie77
A ZZ4 is a great unit and will pull your car along very nicely.
http://corvettec3.ca/zz4.htm
Brown78's Avatar
Brown78
I got a ZZ4 385hp fast burn w/ alum heads. The long block. Everything but the carb, plug wires, starter. I get 18 mpg. Excellent get up and go. Best buy for the money. Don't waste your money by having your stock engine rebuilt. Unless you can do it yourself. I don't trust speed shops. No warranty. It's always defective parts not the installation.
Old Aug 3, 2007 | 07:28 PM
Binnie77's Avatar
Binnie77
Old Aug 3, 2007 | 08:37 PM
max1986weber
Default I think I'm going to go with a 468
I think I'm going to go with a 468. I found a great deal on one. It seems that will be the best engine for what I want.
Old Aug 3, 2007 | 09:05 PM
hjgator's Avatar
hjgator
Default Zz4
I have a ZZ4 in my 79' runs great. Mild enough to run the street.
Old Aug 4, 2007 | 12:32 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
zz572 is hard to beat for a street motor. if you want to stay sb then 396 would be a good choice. the cost is not much more than a 383.
To Best engine for a 79'
