454 Compression help
Old Aug 4, 2007 | 02:21 PM
johns_vette's Avatar
johns_vette
Default 454 Compression help
I want a little more power than the stock 72 454. When I bought the car someone had recently rebuilt the motor. It had a set of 840's which I was planning on using on another engine and I would replace with a set of 781's. I think they may be a little milder and more daily driver friendly.
Here's what I found:
I pulled the heads and found a L2377-30 piston. These pistons have the following characteristics:
Compression with 100.9cc heads is approx. 8.72 to 1, with 106.9cc heads is approx. 8.36 to 1, with 109.4cc heads is approx. 8.22.
The 781's are more like 118cc, so I am thinking this will not be a good match running very high 7.x or low 8.x compression.
How will that low compression affect me? I know I will change the cam to around 500.
To me this sounds like more of a "mis-match" or not the best combination. Any suggestions on how I might improve or will this be fine for a daily driver?
Old Aug 4, 2007 | 02:54 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You'll be going the wrong direction, as new heads with a lower CR and a bigger cam don't add up to performance gains. Rather, you'll actually loose power.
If you're intent on installing different heads and re-camming, it's back to the drawing board time for a complete build-up. If that's out of the question, you should consider pocket porting and angle milling the old heads. That would improve the flow a bit and increase your CR. Then re-cam accordingly, watching your dynamic CR to stay in the sweet spot.
Old Aug 4, 2007 | 03:08 PM
johns_vette
I was actually going smaller with both the heads and cam. These heads (840's) don't even come to life until higher rpm, which I think would be a pain for an a/c car. I don't even know what the cam was but I think it was a larger setup.
I think the problem before that existed was to much cam and heads. I think it was around high 8.
However, I think you are right - I may be going bac for a complete build up and replace the pistons.
I was hoping my goal could be was to save the short block, replace the cam, heads and intake.
Old Aug 4, 2007 | 03:26 PM
TheSkunkWorks
Relative to the particular items you're looking at, I believe you'd be better off with "too much" flow with good CR and well selected cam than the "right" heads and way too little CR.
Bear in mind that with those better ports, you can "under-cam" to get/keep your DCR up and easily maintain adequate cylinder filling due to better flow, while improving port velocity.
With smaller heads, a bigger cam would be needed to flow the same volume, which would even further reduce your DCR.
Old Aug 4, 2007 | 03:31 PM
johns_vette
Thanks! I think I'm catching on. So, really if I went with a head that had smaller cc to increase the compression, I may be hurting myself just by doing such.
Help me here, so I may be able to reduce the cam size to make a better balance of what I have now?
Old Aug 4, 2007 | 03:35 PM
TheSkunkWorks
Don't mean to confuse you here. The smaller combustion chambers are a good thing. What you don't want is a combo of larger chambers and less flow.
Old Aug 4, 2007 | 03:45 PM
TheSkunkWorks
I'll clarify that better. Without changing to pistons with larger domes to get your CR up, you don't wnat the larger combustion chambers. With the right CR, there's nothing "wrong" with the 781's on a mild street motor. However, with the existing pistons the loss of CR would be the greater factor than any flow issues.
I'm just saying that between the two, I'd rather have a good CR with the "wrong" head than a poor CR with the "right" ones. With the former, I can correct somewhat with a cam. With the latter, no cam selection is going to bring it back.
Old Aug 4, 2007 | 03:50 PM
johns_vette
Thank You! I'm slow when it comes to this stuff. Your help is greatly appreciated.
Old Aug 4, 2007 | 04:17 PM
TheSkunkWorks
Hey, doing your homework takes time. Better than making the wrong snap decision.
Post up when you get ready to nail down your cam, and you'll get plenty of advice on here.
Old Aug 4, 2007 | 10:43 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try a short duration single pattern cam first.
If u have a low c.r. motor wether sb or BB u want to run a short single pattern cam (<270* full duratiuon). What cam do u have now? U may already have a small cam now but u need to pull the timing cover to read the cam numbers to find out. What a short single pattern cam does is close the intake vlv sooner on the compression stroke and trapping more A/F mixture/better cylinder filling than a longer duration cam would. U won't need the longer duration on the exh as with the dual pattern cam for increased exh blow-down - it will only lower your vacuum.
Well i'm not familiar with BB heads but u want a tight chamber to keep what compression u have - any larger chamber will only reduce compression.
If your on the learning curve here (as most of us) then my advice is u should try a cam swap first for the experience before u spend big $$$ on a full overhaul - maybe your first try and too much to learn. Nothing ruins your enthusiasm more than to spend $2K to overhaul and many hours and have the engine eat itself from bad clearances or bad parts.
Hope this will help.
cardo0
Old Aug 4, 2007 | 11:11 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I just finished a 74 LS4 with flat tops / .30 over / CompXE268 flat tappett / stock manifolds and carb. Has a slight rough lope but make crazy smooth tire smoking power through 5000 .... then it spits up and wants a nap.
Old Aug 5, 2007 | 01:50 AM
johns_vette
cardo0
Hello, Well I don't know what cam is in the motor, it's not labeled. I know it was a large cam. I will be sure to use your advice on the duration.
John
To 454 Compression help
