rear trailing arm spindle snap?
A little back ground info is that there are 100% new complete trailing arm assemblies from VB&P installed in December last year and have around 4,000 miles on them with my little whimpy 205rwhp rebuilt L46 powering my car so it is not like I got huge amounts of power to snap stuff. Also recently installed yesterday brand new 3" half shafts with spicer joints with the first time testing them out on the road. Also recently installed a Dragvette 6 link kit that I must say without a doubt the half shaft safety loops saved my battery box and rear shock as that safety loop got the crap beat out of it so the Dragvette kit has already in some respects paid off.
Thats a guess, I never thought about any of that until Robs spindle broke.
With the stock suspension, the rear halfshaft is actually part of the "link" stuff, holding the trailing arm in a plane, and the c-clip is required, right?
Regardless, better pics would be very helpful.
I would post pics...but being my luch my camera that was working fine on Sunday decided to not work now. I hope its only a dead battery.
Anyway....I am now seriously on the hunt for a custom half shaft know as a "slip shaft" similar to Mark's (84rzv500r) that will be splinned and be adjustable in length that way I don't have to worry about this c-clip/binding stuff. I went to 4 driveline shops today all very old school truck shops and none of them had a clue of what I wanted. Mark got lucky I guess finding a good driveline shop where they knew what he needed. I show pics of Mark's setup and they all say...WOW!!! but can't help me any further as it seems all these guys are just interested in cranking on the usual truck stuff.
btw...believe it or not my c-clips are not broken as there is still less than 1/8" of side-to-side movement.
What I meant was....using a 6 link without a johny joint you will most likely get binding as the wheel moves up and down b/c the wheel will still travel in a slight verticle arc but the TA bushing will only want the wheel to move up and down with no arc. A rubber bushing gives the TA some movement, poly less movement. A johny joint gives the TA a good amount of freedom to move how it wants, giving the TA the option of moving more in that vertical arc. The johny joint will help prevent binding throughout wheel travel however the whole point of the 6 link is to keep the tires level (full tire contact with ground) so there can be no vertical arc.
It would be ideal to have the telescoping half shafts that Mark has, i've only seen them on one other car and it was a wide body also. I've never seen a Dodge Viper's half shafts but I have been told they are somewhat similar in design.
Keep searching for someone to build those half shafts and get those TA's rebuilt in the mean time. If you have the cash and plan on running this car hard in the future now is the time to upgrade those TA spindles with Tom's Diff's 12 bolt style and upgrade the diff to the 12 bolt. Tom might sell you just the half shaft ends (12 bolt style) for you to put onto your telescoping half shafts when you get them.
If Toms setup is too expensive I'd replace with some heat treated heavy duty spindle parts.
Good luck
Good luck
Some here would say that this is NOT a place for a Poly bushing. I tend to agree.
I will say that with my setup the Ride quality is vastly improved and the suspension is far more compliant as in no binding and greased pivots in all directions. The buck board harsh ride is gone.
While I have not had the car under racing conditions I have a spot of road that I use to test suspension. we have a sweeper on the interstate with two bridges close together. That is 4 pavement transitions in a corner at double digit speeds 75-80...
Stock suspension with the same shocks and rear spring wheels tires tire pressure ect.. I have now would upset the car at 75 and each joint would cause the car to step sideways.
Only changes was 6 link and wilwoods at each corner and while I get a feel the transitions are there the car is not upset and tracks smoothly through.
I do have years of MC roadracing experience and have collected my share of 1099's doing it. I find that a setup that works well on most race tracks including bumpy ones like Neslon Ledges would be unbearable for any distance on the street. As the streets and interstates here in the northeast are far to rough. I think that experience would translate mostly. The quality and adjustability of the components I have on my MC FAR FAR exceeds anything I have seen used here on C3's.
Prior to the 6 link I would say my corvette would NOT out handle my 93 civic ex with sticky 17's Now I'm quite sure the honda would have some difficuly.
I'm gonna find out at an autoX a week from this coming Sunday
YES the 6 link is comprimise! NO i'm not going to race it at Watkins or Mosport or Calabogie or Pocono or VIR or NHIS or Limerock. I may do a track day and I will do some local autoX.
SEAT TIME makes you fast ALMOST independent of the equipment....
Hijack Over
Try to take some video of yourself on the track, I'd like to see your car in action. You got a buddy who can watch with a video camera or a rollbar mounted camera?
Can you take some pics of your setup on the car? I saw some brackets in one of your pics that I've only seen on a solid axle to adjust the ladder bars. Your pic at the bottom.
In order to get the combo to work right, you would have to have slip type half shafts.
the brackets were my First Design for the upper outer brackets... They needed to be modified to fit the car...
I have enough trouble seeing this 15" monitor as it is......
