When gravity bleeding the rear calipers should both bleeder valves be open on both rear calipers or should the right rear be done first, then left rear?
Also should both bleeder valves be open or inner first then other or other first then inner?
To properly gravity bleed, open rear bleeders. If you have two bleeds in each rear caliper open the ones at the highest position on the caliper.
Leave the cap off of the master but make sure it's topped off.
Sometimes it takes a around a full day, 24 hours, for the fluid to make it all the way down to the back calipers and start dripping out. That's the goal. Gravity should pull the fluid from the master down to each caliper.
I screwed around with mine for weekend trying to get air out by this method, must have gone through two big bottles of fluid. I finally broke down and bought a pressure bleeder and got the job done in 15 minutes. It's a VERY worthwhile investment!
Your rear calipers should have two bleeders at the top - inner and outer. They both need to be bled. Don't bleed the one at the bottom. Do one bleeder at a time.
I tried for 2 days to bleed mine and still could not get all the air out. I have a pressure bleeder on order. Save yourself a lot of time and grief and order one from summit racing. Cost me $70 with shipping
ME being cheep....drill two holes in the top of the m/cyl lid...reinstall with the intact gasket....don't drill IT....and full of fluid....take your air hose and lightly pressureise the sector that wont' bleed right....
this forces fluid down with no up stroke on seals....obviously the bleeders are open...one is fine for the rears....when there is lotsa air in the lines, the seals on the relax stroke just allow the air to de compress and don't do a damn thing about forcing fluids through the lines...
hense my concept of a built in pressure from top bleeder....works fine for me...obvously seal the top holes with RTV something, clean...
This is what works for me. I connect a clear hose from the bleeder screw into a bottle with some brake fluid in it. Make sure the tube fits tight at the bleeder and the end of the tube in the bottle is covered by some fluid. Position the bottle about the same height as the bleeder screws. Fill up the master cylinder put the cover on. Open the bleeder screw and slowly push the brake pedal to the floor and then let it snap back. Repeat this about 10 times, then close the bleeder and check the fluid level in the master cylinder. Check the hose from the bleeder to the bottle, it should be full of fluid with no air bubbles. Repeat the process until there are no signs of air. Hope I explained this correctly it works great for me.
