Odd openings in the core support.
Old Aug 7, 2007 | 08:19 AM
Block_Head's Avatar
Block_Head
Default Odd openings in the core support.
In my radiator core support, on each side about half way down are some odd openings. They are almost big enough for a child's hand to slip through.
What is the purpose of these holes? A bundle or wires and vacuum hoses go through the one on the driver's side and the one on the passenger side has nothing.
Anyway, a lot of air is going through those holes and I feel that's hurting the cooling system.
Is there a reason I should not stuff some foam in those holes?
Thanks.
Old Aug 7, 2007 | 10:13 AM
Artsvette73's Avatar
Artsvette73
Head light harness and vacuum line on the driver side and A/C lines on the pass. side.
Old Aug 7, 2007 | 10:29 AM
Block_Head's Avatar
Block_Head
Okay well I think the ac system was removed from my car long before I got it.
Is it safe for me to plug them up with foam or something so long as the wires and vacuum lines still go through as before?
I just want to seal it all up as well as I can.
To Odd openings in the core support.
