Actually just disconnecting the vacuum lines won't make them go down. There is an actuator that pushes a spring loaded leg out of position allowing the lights to lower. You have to have just as much vacuum to lower them as you do to raise them.
If they won't lower that means that either there is a vacuum leak, or that either the relays or actuators are bad.
If they both exhibit the same symptom then it's probably a leak in the system or the switch.
Theres's a switch under the steering column. Move that and the lights will drop. But, as mentioned above, you have a leak likely in the system from the sound of it.
Disconnect the vacuum lines going to the actuators. They should close right up.
Actually Jim its just the opposite.I think you mean remove the small white striped hose going to the actuator.
Vac. on the actuator makes them go down. Vac. removed makes them go up.
So if UKs problem is on the small hose side of the system then he is lacking in vacuum at the actuator.
Yes apply vacuum to the actuators at the small hose ports.
You can manually drop them by reaching up under and pulling in the center pivot of mechanism.
A default 'safety' mechanism is that if the vacuum fails the lights will open. Thus the simplest explanation is that vacuum holds the lights down. If your lights won't go down, you likely don't have any vacuum.
