air cleaner advice
on a air gap manifold from the research that i have done i need to drop the air cleaner 1.5 inches to keep the stock hood. i can mill .500 off of the manifold does the 1969 drop base fit a 4150 holley and does it drop close to an inch? if not any sugestions?
thanks for any help
donnie
You need to compare the stock LT-1 aircleaner base with what you've got to see if it will work.
I am trying to keep the original air cleaner assembly so it will make use of the cowl induction i will fab the rest of the assembly to that base if it works .
L 88 and LT1 are the same?
thanks donnie
