Offset T-Arm Sale
Old Mar 12, 2008 | 04:41 PM
  #41
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The sale is back on!!!
C2 & C3 (63-82)
Bare offset t-arms are $350.99 and include
Part Number TA-06
• Gloss Black Powder Coating
• Rubber or Poly Bushings
• Spring Bushing Retainers
• Cable Guides
New T-Arm Studs are $12. for all 8 and includes lock washers and nuts.
Complete Offset T-Arms are $970 for the pair. Core charge is $390.
Part Number BAO-44-L/R
• Complete offset t-arms include
• Both offset t-arms
• New backing plates
• Bearing supports
• Spindles
• Caliper Mounting Brackets
• SS Paring Brake Hardware
• New GM Style Shoes
• New Rotors
• Timken Bearings
New T-Arm Bolt & Shim Kit $44.99
Part Number TA-23S
• Kit includes SS Shims to align both the right and left side.
• 2 New pivot bolts with washers, nuts and cotter pins.
Here are the 3 links provided to order online. Prices are already adjusted on our site. You can call your order in as well. There is a 1 week lead time for the complete offsets.
Complete Offset
http://www.vansteel.com/index.cfm?fu...p=1892&ID=2784
Bare Offsets
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1837
T-Arm Studs - Mounts the arm the the bearing assembly (2 kits required)
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1705
T-Arm Pivot Bolts & SS Shim Kit
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1860
Old Mar 12, 2008 | 05:04 PM
  #42
Billysvette's Avatar
Billysvette
I have a question,can i run 15 inch wheels ,10 inch wide,without any problems with the offset arms?I want to run 10 inch wide and fit it under the rear fenders.
Old Mar 12, 2008 | 05:10 PM
  #43
Van Steel's Avatar
Van Steel
not unless you have flares. Your wheel well gap is 11" wide. The sectional width of the tire, not the rim, would more than likely be over 11" wide. Plus you'll have to shorten the rear spring for additional side wall clearance. No rear bar either. Your best bet for a 15" rim is our double offsets which have the spring bolt hole moved in 1" from stock. You definetly need to have the rear spring shortened with these too. 1" on each end.
