steering box question????
Old Aug 9, 2007 | 08:52 PM
435/427BB's Avatar
435/427BB
Default steering box question????
to set play in the box, bottom out the screw and then back out how much? what happens if it's too tight? thanks
Old Aug 9, 2007 | 10:08 PM
stock76's Avatar
stock76
It is very difficult to properly adjust a steering box in the car. There is a GM service procedure for it but I think you still have to disconnect the pitman arm. It is best done with the steering box completely out of the car using an 0 to 30 inch pound or 0 to 75 inch pound torque wrench with the box secured in a vise. You can do some serious and expensive damage to the box if you adjust it too tight. If the steering wheel does not return freely on its own when cornering and you have to pull it back, then it is adjusted too tightly.
If you have a lot of play in your steering, check your rag joint, all your suspension and power steering components (and wheel bearings) first before messing with the box.
Go to http://jimshea.corvettefaq.com for excellent how to articles on steering
best of luck
Old Aug 9, 2007 | 11:17 PM
Jim Shea's Avatar
Jim Shea
You may be interested in this paper that is posted at the www.corvettefaq.com websight. The following is a direct link.
http://jimshea.corvettefaq.com/wp-co...-Rev25JA06.doc
Jim
Old Aug 10, 2007 | 08:06 AM
435/427BB's Avatar
435/427BB
thanks fellas for "steering" me in the right direction!
To steering box question????
