Holley main bodies
Have I got this right, or is it somthing I have missed???
Is it only the main body that differs between a 650 dp and a 750 dp?
Are the baseplate and metering blocks the same on both carbs?
http://store.summitracing.com/partde...5&autoview=sku
http://static.summitracing.com/globa...-199r10355.pdf
________________________________________ ______________________
388 ci , 440HP @ 5700 rpm, 460 ft/lbs @ 3500 rpm
Trick Flow 64/195 CNC heads, 700 CFM Holley dp, 2 1/2" in. exhaust, Performer RPM
CC CS XR280 Exteme Street Solid Roller 242/248 @ 0.050 - .570 in /.576 ex
CC Super Roller, Eagle ESP crank, Manley rods 6.0", Probe SRS pistons 11.3 CR
Video:Click here! Photos:Click here!
Also, the floats in the HP are different, made of that black plastic material with cutouts for jet extensions, and of course the HP has the jet extensions -- both of which you can buy as well. The HPs also have PV blow out protection, which I dont think you can add without changing the metering plates.
But still I think the engine needs more air when looking at the dyno results.
