Front Coils
Old Aug 10, 2007 | 09:41 PM
RxForPain's Avatar
RxForPain
Default Front Coils
I want to replace the front coils on my 71 coupe (TH400 and A/C) when I have/do the front end. I really want to stay as close to stock as possible and my local supension shop suggested I switch to big block coils.
Any suggestions would be appreciated.
Old Aug 10, 2007 | 10:25 PM
Durango_Boy's Avatar
Durango_Boy
Do you have a small block or big block. If you have a small block don't get big block springs. The nose of the car will sit too high.
Old Aug 10, 2007 | 10:47 PM
SmokinBBC's Avatar
SmokinBBC
Call the experts at VB&P and let them know what you want to do. They are great with suspensions.
I put a 360 mono on the rear and 550 coils on the front. Matched it with Edlebrock IAS shocks. I love the ride. The VB&P 550's actually lowered my front by 1".
Old Aug 10, 2007 | 11:09 PM
The Money Pit's Avatar
The Money Pit
My VB&P 550 lb springs have the fender lip at 27 1/2" from the center of the well to the ground. That's with P245 60 front tires and a smallblock 406. Ride is firm and corners flat.Wouldn't change them to anything else.
Old Aug 11, 2007 | 12:22 AM
RxForPain's Avatar
RxForPain
I currently have a small block, but the local shop was trying to get me to go with the big block springs because of the A/C and TH400.
Old Aug 11, 2007 | 08:05 AM
72 LT1's Avatar
72 LT1
I too run the VB&P 550 coils in front but have a 330 glass spring in rear w/ Bilistien gas shocks all around. Althou the ride is not "terrible", to say the ride is firm, is being kind. It's pretty stiff. I agree the car corners flat, and the rear seems to ride fine. The car "sits" good in the front, not slammed, but low. The front end lets you know of even the smallest pothole/road imperfection. I run 60's series tires on stock ralleys. You can expect an even worse ride if your using 17's w/ low profile tires. There GT 460lb coils will be a better riding spring. You didnt state weather you have aluminum heads/intake/rad/ or headers. All of those things remove weight and can allow the front end to "sit" too high. My vette is a small block w/ all of those items. Its also a 4spd car w/p.s. being the only option. Its a fairly light car (as far as c3's go) and the front end was too high. The only reason I went w/550 coils was for the lower ride hieght. Your car may be heavy enough to "sit" right w/ the 460 coils, allowing you an improved ride. Just my .02.
Old Aug 11, 2007 | 08:16 AM
ltlevil's Avatar
ltlevil
No Way Would I do this. Do as stated elswhere in this thread-call VP&B tell them what you have and also tell them anything you plan on doing later.
ltlevil
Old Aug 11, 2007 | 10:37 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Factory front springs were about 280 - 300 lbs/inch for small blocks. However, stock replacement springs were usually about 500 lbs/inch.
Unfortunately, noone sells the 280 - 300 lbs factory springs.. If you get lucky at a swap meet, you might find some new old stock springs.
You can tell by looking at the springs. The 280 - 300 lbs/inch springs are very long and have thinner coils than the replacement springs. If you get for example stock replacement springs form Ecklers or any other parts store, you will get about 500 lbs/inch and a much stiffer ride but better handling than the stock springs. Other options are the 460lbs/inch or 550lbs/inch springs that VBP sells. You won't find any springs with the stock spring rate except for NOS (new old stock).
The only thing that the stock springs are good for is Drag Racing as they are very soft. You will get better handling with any of the replacement springs.
The 550 lbs/inch springs actually lowers the ride height compared to the stock springs (when new). However, compared to old worn out springs, the 550 lbs/inch springs might have similar ride height.. Worn out stock springs can drop as much as 3 inches..
Old Aug 12, 2007 | 12:16 PM
FKING1's Avatar
FKING1
I bought a set of new frt coils for my 70 small block and cut one coil off to get a nice ride height.
Old Oct 17, 2007 | 06:07 PM
10sec75's Avatar
10sec75
I have the 550. Small block, th400. Exact same ride hieght as the stock springs I replaced. (27 3/4"). If you want any handling at all, go with the 550's.
Old Oct 17, 2007 | 06:23 PM
wolfyffs's Avatar
wolfyffs
I replaced mine with a set from Zip. They set nice & ride & handle well. Mine is a small block with all the accessories on it. They are priced fairly well from Zip also.
Old Oct 17, 2007 | 08:49 PM
Kalway's Avatar
Kalway
Didn't the late Gymkhana Suspensions come with like 550 lb. front springs?
Edit:
Aha! Unless they changed it later, the gymkhana suspension did indeed come with 550 lb. front springs.
http://100megsfree4.com/corvette/1970/vet74.htm
Old Oct 17, 2007 | 10:09 PM
72LS1Vette's Avatar
72LS1Vette
The VB&P 550 big block springs are advertised to lower the ride height 1" over the stock springs.
Rick B.
Old Oct 17, 2007 | 10:46 PM
pbcanney's Avatar
pbcanney
these trw springs are short money on a popular website. but what are they? Gymkhana?
This is a set of 2 TRW Coil Spring FRONT WCS5762 FOR:
CHEVROLET CORVETTE 1963-1982.
INSIDE DIA.= 3.825 in.; BAR DIA.= 0.656 in.; FREE HEIGHT= 13.13 in.; SPRING RATE= 474 Lbs./In.; LOAD= 1061 Lbs.; LOAD HEIGHT= 11 in.; END 1= TANGENTIAL; END 2= TANGENTIAL
Old Oct 18, 2007 | 10:13 AM
TWINRAY's Avatar
TWINRAY
My '69 is a SB w/air. I know about 4-5 yrs ago when I replaced my springs there weren't many listings for them I think I went with Corvette Central.
Old Oct 18, 2007 | 10:59 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
It's the other way around. Aftermarket SB springs at free length are 13". BB are 12" and. BB spring in a SB car will lower it 1".
Old Oct 18, 2007 | 11:39 AM
Durango_Boy
I guess I thought he was looking to buy stock springs.
To Front Coils
