Quick brake question
Old Aug 11, 2007 | 10:31 AM
PolishMike's Avatar
PolishMike
Default Quick brake question
Ok, so i have a brand new VBP brake kit installed and am now trying to put the fluid in the first time. I am trying to bleed the system and I get fluid going to the front brakes but not the rear.
Any ideas?
Old Aug 11, 2007 | 10:36 AM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
How far back are you getting fluid?
Is there a leak anywhere?
Check your brake lines for kinks.
Also, it takes a lot of brake fluid to get to the rear (long distance of travel).
Old Aug 11, 2007 | 10:40 AM
Dantana's Avatar
Dantana
I will be very interested in how you solve the problem. I've got to order a new kit from VB&P this week since my brakes, front and rear, are completely shot (don't work at all) and the car is stuck in the garage.
Did you buy the C5 upgrade kit for the fronts?
I'm curious how it all went together...
Old Aug 11, 2007 | 10:49 AM
...Roger...'s Avatar
...Roger...
Any ideas?
Did you bench bleed? Are you gravity bleeding?Are you rushing it,if you are gravity bleeding it takes a long time for the fluid to reach the rear.
Old Aug 11, 2007 | 11:39 AM
PolishMike's Avatar
PolishMike
I did not bench bleed. I am going to do this when i get home. From what i see the fluid is being pulled from the front fluid reservoir on the master cylinder and not at all from the rear one. This leads me to believe that the fluid is not going anywhere to the rear. What could cause this?
Old Aug 11, 2007 | 12:29 PM
...Roger...
The fronts are easy and they move a lot of fluid.The rears dont move fluid fast-it takes awhile.
If you stepped on the brake pedal without first gravity bleeding you could have upset the proportioning valve.Once you remove the master to bench bleed -it should reset.After you bench bleed and put the lines back in the cylinder-tap the fittings at the master before tightening up to help the air to come out especially the rear fitting.Then let the gravity move the fluid to the rear after opening LR inner bleeder.Dont do a lot of pumping this makes foam and foam is hell to get out.
Old Aug 11, 2007 | 08:40 PM
70 LS1's Avatar
70 LS1
There is a way to bench bleed with the master still in the car. It is not as easy as pulling the master cylinder, but it is easier than trying to push the master piston by hand on the bench.
First disconnect your brake lines from the master. Then attach two short lines to the master and route them back up into the resevoir. push on the brake pedal several times until there are no more bubbles forming in the resevoir.
Here is a pic of how the lines look routed back to the master.
Old Aug 12, 2007 | 12:17 AM
PolishMike's Avatar
PolishMike
I actually went out and bought another master cylinder just in case. Bench bled this brand new cylinder and put it on the car. I now have fluid going to the front and rear. Unfortunetly though i am unable to build pressure in the brake. I checked for leaks everywhere and tightened every connection i could. When i loosen a bleeder on the back fluid comes out, and pretty steady with no air, however the pedal is still going to the floor.
Any ideas?
Old Aug 12, 2007 | 01:38 AM
70 LS1's Avatar
70 LS1
Did you do all the bleeders? In the correct sequence? There are two bleed screws per caliper.
Also, when you bleed the brakes be prepared to go through a lot of fluid. I think I went through two quarts just the get the pedal feel I like. Just keep bleeding in the correct sequence and you will build pressure.
Old Aug 12, 2007 | 01:38 PM
PolishMike's Avatar
PolishMike
So should the brake be able to get stiff before i start bleeding or not? Also what is the correct order just for the record
Old Aug 12, 2007 | 04:10 PM
...Roger...
GMs recomended bleeding order:
left rear inner,left rear outer,right rear inner,right rear outer,left front,right front
Old Aug 12, 2007 | 07:17 PM
dannyman's Avatar
dannyman
Proportioning or Brake Warning Switch may be stuck. If your brake warning light is illuminated on the dash you will need to re-centre your switch. Follow brake lines from master cylinder to next component downstream, this is the switch. It will restrict the fluid flow to either the front or rear brakes if not in the center position.
Old Aug 12, 2007 | 07:58 PM
PolishMike's Avatar
PolishMike
Dont know if the light is on or not, will check that tomorrow.
How do i center the switch if i need to?
Old Aug 12, 2007 | 09:22 PM
dannyman's Avatar
dannyman
Think of this switch as a sleeve with a piston inside. When the switch is not activated (no brake warning light on dash), switch is in centre position. If either the front or rear loses brake pressure because of a fluid leak, the piston moves internally from the centre position to one end of the sleeve, restricting fluid pressure to one half of the brake system and illuminates the warning light.
In order to re-centre you have to apply a hard brake pressure application. Generally you will need to have good pressure on both front and rear brakes in order to re-centre.
You can find more information by looking for proportioning valve, brake pressure warning or combination valve, in manuals or search. Unfortunately, this switch/valve goes by many names.
Old Aug 13, 2007 | 12:34 AM
PolishMike's Avatar
PolishMike
Ok i believe that is what happened. However i hooked up a little hand vacuum pump to the rear brakes and that must have popped the control valve back to center because all of the brakes are now getting fluid.
Should i be able to push the pedal down to the floor? I was under the impression that i should not be able to do that.
Old Aug 13, 2007 | 01:28 AM
70 LS1's Avatar
70 LS1
If you can push it all the way down, you probably have a leak somewhere. You should be able to build at least a little pressure if you pump the pedal.
Old Aug 13, 2007 | 02:05 AM
PolishMike's Avatar
PolishMike
pressure builds a bit as the pedal gets harder and harder to push down but i am still able to push it to the floor.
Is there anywhere it could be leaking that i wouldnt be able to see fluid coming out? Ive checked every possible connection and they all seem fine... Any sure ways to check? ie air compressor rigged up to a bleeder?
Old Aug 13, 2007 | 06:45 AM
dannyman's Avatar
dannyman
You still have air in the system! Keep bleeding until you have good pedal pressure. If you have a leak it will be obvious, fluid can't hide.
To Quick brake question
