Roller block & oil dip stick ?
Old Aug 11, 2007 | 12:48 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Roller block & oil dip stick ?
What dip stick are you using with the roller block? I just shoved in a universal SBC & my crank abused it. What do I need?
Old Aug 11, 2007 | 01:17 PM
Durango_Boy's Avatar
Durango_Boy
Is the oil pan on the block the one that came with it and do you know what year and model vehicle the block came from?
Old Aug 11, 2007 | 03:46 PM
ratflinger's Avatar
ratflinger
New Chev roller Gen 1 block & Hamburger 6 qt pan.
Old Aug 11, 2007 | 04:08 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'm using a Lacare dip stick for the roller blocks. I had to clearance my aftermarket pan so it would work.
Is your pan deflecting the stick into the crank's path? The dip stick should go right between two of the counterweights.
Old Aug 11, 2007 | 05:03 PM
Edzred72's Avatar
Edzred72
Do you need a lower dipstick tube like old standard blocks use?
It's a small length tube that gets installed in the blocks lower dipstick casting that keeps the dipstick straight & away from the crank.
Eddie
Old Aug 11, 2007 | 07:04 PM
ratflinger's Avatar
ratflinger
Eddie,
I might, but I haven't seen these for sale at Jegs or Summit. I'll be pulling the pan back off to check the stud torques, so it will be a great opportunity to correctly place a dip stick.
Old Aug 11, 2007 | 11:35 PM
Edzred72's Avatar
Edzred72
Eddie,
Pretty easy to just pound in from the bottom with the pan off. There should be a "stop" cast into the block so the tube only goes in so far. Got mine from either DocRebuild or Paragon when building the 406.
good luck
Eddie
Old Aug 12, 2007 | 09:38 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Im using a Mr. Gasket one I bought for 12 bucks from O Rilley Auto Parts
To Roller block & oil dip stick ?
