Tach Drive HEI Electric hookup?
Old Aug 11, 2007 | 02:57 PM
BT74's Avatar
BT74
7th Gear
Default Tach Drive HEI Electric hookup?
Done a search and only came up with some ambigious threads. (Sorry if this has been addresedbefore). Installed a Speed City HEI and looking for a 12V power source. Hooked it up to the throttle solenoid, and can't get it to fire. Hooked up a volt meter, and it went from 12v to 0v when cranking(and realized that it had voltage on the Acc position of the ign switch).
Seems a lot of folks bought distributors(tach drive) from Speed City, and was hoping to hear how you folks powered them up(at 12V non-resisted switched power). Hoping for a source already under the hood, rather than bringing it thru the firewall. Thanks for any info.
Old Aug 11, 2007 | 03:08 PM
lil_red_devil's Avatar
lil_red_devil
On a vette I converted a while ago I used the (I think) pink wire that comes thru the firewall and connects to one post of the ballast resistor. The other post was connected to the coil. You need to get rid of the ballast resistor anyway and from what I remember it can reach the HEI without any other mods other than maybe a spade connector.
Hope this helps
Old Aug 11, 2007 | 03:58 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If it has resistor wire, that will need to be swapped out.
Google is the bearer of great wisdom:
http://www.oldengine.org/unfaq/hei.htm
http://www.pontiacstreetperformance....onversion.html
To Tach Drive HEI Electric hookup?
