electric feul pump question
Old Aug 11, 2007 | 05:10 PM
TFitz's Avatar
TFitz
Default electric feul pump question
Do all elec.feul pumps regulate themselves or should I have some sort of regulator on it. the one i had seemed to slow down after running a bit. the new one runs on the whole time the car is running and feels hot after is has been running for awhile. The new one is a holley red pump. Thanks for the help.
Old Aug 11, 2007 | 05:28 PM
SIXFOOTER's Avatar
SIXFOOTER
you need a regulator, put it on the carb
Old Aug 11, 2007 | 05:32 PM
76 sting's Avatar
76 sting
The maximum pressure on the Holley "RED" elec pump is 7PSI so I would not think you need one.
Old Aug 11, 2007 | 06:05 PM
mrvette's Avatar
mrvette
Depends.....a Qjet takes like 4? lbs...really LO pressures, a Holley/AFB can take higher pressures.....but as I recall....8 lbs is pushing the limits....
so at 7, IF there is a Qjet on there, it's same as I had once, needing a line regulator up top near the carb....dialed for 4 lbs, and that 455 Poncho ran like a scalded dawg....
Old Aug 11, 2007 | 06:07 PM
76 sting's Avatar
76 sting
Good addition.... I did not realize they use so little.
To electric feul pump question
