Rear Wheel Slant
Old Aug 11, 2007 | 09:59 PM
jtg700's Avatar
jtg700
Default Rear Wheel Slant
Hello. Probably a dumb question, but here goes: Whenever I jack up the rear of my 1980 Vette, the wheel slants quite a bit - top (12 o'clock) moves so that 3/4s of the tire is outside of the wheelwell, and obviously the bottom (6 o'clock) is way in. When I let the car down, the wheel (or wheels) stay like this until I roll the car down the driveway a bit. Is this normal, or is it indicative of a problem? I assume that its ok in the air, but when I let it down, shouldn't it straighten out by itself without my rolling it? That really bugs me. Thanks! JG700
Old Aug 11, 2007 | 10:04 PM
...Roger...'s Avatar
...Roger...
The straightening after rolling is normal.The tire hanging out sounds like the snap ring on your yoke has popped off or the end is worn off.
Old Aug 12, 2007 | 04:55 AM
tkdsnz's Avatar
tkdsnz
5th Gear
You can tell if the snap ring is missing. Just jack the car up so the wheel is of the ground, if you the push and pull on the wheel it should only move a small amount and have a possitive stop at both ends of the travel.
To Rear Wheel Slant
