Frame Question
Old Aug 12, 2007 | 12:03 PM
2005bobby69's Avatar
2005bobby69
Default Frame Question
Hi all,
does anyone know if a 68 - 69 vert body will fit on a 75 frame
thank you
Old Aug 12, 2007 | 03:02 PM
Artsvette73's Avatar
Artsvette73
You have to graft the rear frame rails and crossmember to accept the 68-69 bumpers. If you have an automatic trans make sure it has the removable croosmember for the trans. It won't matter either way if you have a manual trans.
Old Aug 12, 2007 | 08:18 PM
72LS1Vette's Avatar
72LS1Vette
You also have to switch body mounts from solid mounts to either rubber or polyurethane.
Rick B.
Old Aug 12, 2007 | 08:29 PM
gator79's Avatar
gator79
looks like a lot of work and you need a donor, nice job
Old Aug 12, 2007 | 08:51 PM
jomor's Avatar
jomor
Not sure, but I think the convertible chassis had more stiffening members to compensate for the roof loss. Better check that if you plan to use a coupe chassis in place of the convertible chassis.
Old Aug 12, 2007 | 08:54 PM
gator79's Avatar
gator79
I think they are the same frame. I had 71 vert and a 72 coupe down to the frame and they were the same, no extra bracing. there is extra bracing behind the dash in a vert .
Old Aug 12, 2007 | 08:56 PM
Dick Whittington's Avatar
Dick Whittington
Frames are the same between coupe and conv't. Convertible has extra mount to stiffen body
To Frame Question
