blower relay replacement
Email me a picture of this and I'll help you figure this out!
Send it to: Willcoxcustomerservice@willcoxcorvette.c om.
Willcox Inc.
). It appears to be some kind of aftermarket hi-blower relay, with alternate, aftermarket wires running to switches inside the dash. my concern now is...where does the other 4 little wires go into the dash?? another day, i guess. any info would be helpful. Thanks.http://i229.photobucket.com/albums/e...h/DSC00023.jpg
http://i229.photobucket.com/albums/e...Aug21_0001.jpg
http://i229.photobucket.com/albums/e...Aug18_0002.jpg
the purple wire goes to the blower motor as it's single power source, Just that wire, and a Gnd. The other end of the prl wire goes two locations. 1. the output of the resistor matrix, for all the lower speeds.
2. The blower relay. The blower relay shorts the 2nd stub of the blower power (purple) lead to the Orange (Full 12 V, no resistors) wire for full power. It can do that because there is just one Voltage source and current doesn't flow up hill so to speak. If your having a problem with the fan on high, the post tells you how to determine what it is, but you will need a volt meter, and have to follow the ideas listed. Either you have 12 volts at the end of the Orange wire or you don't. Either the green controll wire is going to High (12V) or it's not. theres also a plug on the blower fan lead. You can take that appart and check there if the other two things are present. If so, but it stilll doesn't work, this would point to a bad relay. Remember, there is a fuse in the orange wire near the power junction. If it shorted when it wraped, it blew this fuse for sure. C.
