Speedometer needle - ?
Old Aug 14, 2007 | 08:37 AM
Lee70454's Avatar
Lee70454
Default Speedometer needle - ?
Went to a local car show last night, speedometer was working. On the way home got on it a couple of times (zz454/TKO 600). Driving to work this AM, I notice the speedometer needle missing on the long side of the pivot and not registering correctly. Weird thing is I can not see the broken off needle portion inside the speedometer housing...only thought I have is it slipped down into the area/slot where the odometer numbers are located. Any thoughts out there? Anyone know who rebuilds/fixes odometers?
Old Aug 14, 2007 | 09:09 AM
gldnkngt's Avatar
gldnkngt
The long end of the needle is probably inside the case. Check my profile and website. I can fix that for you.
Old Aug 21, 2007 | 10:49 AM
yel76low's Avatar
yel76low
Same thing happened to me.
Old Aug 21, 2007 | 10:53 AM
Gordonm's Avatar
Gordonm
I had my tach needle do the same thing last year. It just disappeared. When I got it apart it was in there just way down in the tach. I have since replaced the needle and converted it to electric.
To Speedometer needle - ?
