I need to bump up my compression ratio. In order to do this I was going to switch to a .015 compressed thickness gasket which would only be 3.2cc of volume which should bring me up about a half a point. I called Fel-Pro and they told me I can't run a .015 thick gasket on the street since that is not what it was intended for. Is this guy just reading what the book says or is he actually right.
Have these on my built 327, using aluminum AFR 180 Eliminator heads. Got these #1094 before they were officially out from the hiperf engineer who designed them.
Surface finish is a concern, these aren't to be swapped with just anything. Surface finish must be ideal and machined within a range (sorry don't have Ra spec handy) in order to seal. Composite gaskets are a little more forgiving in this regard.
Plus aftermarket heads usually have a thicker deck surface and have little to no head deflection (bending) when torqued. This ensures compression of the emboss beads in the gasket. Also the thicker deck surface aids in compression of the wire c.o. ring that under the armor in composite #1003 head gaskets.
Bottom line, depends on the hardware your using. Stock heads, use the o.e. gasket. Even the #1003 sometimes don't seal on stock heads because of head bending. The ring doesn't compress and prevents clamping of the body/coolant ports and can weep coolant.
They are some sort of dished piston on a 4 bolt main block with the factory deck height. It was a gm performance crate motor bought in 86, or at least that is what the guy told me that I got the car from. Which could be absolutely wrong since he was dumb enough to blow the stock engine. It has a .041 thick on it now.
Me thinks you should pull the heads off & check this stuff before you decide on a gasket. Get us a down in hole measurement and pics of deck surface & piston tops.
-edit- unless they are truly needed, I'd suggest heads without heat Xover. Unless truly needed, suggest blocking both Xovers at head with a thin steel shim. FYI, some chokes are dependent upon Xover but can be modded.
There is no point in buying anything until you get the heads off to know exactly what you are dealing with. There are plenty of this and that guys out there that have no idea what they are talking about and this kind of sounds like the guy you got it from if he can't produde a receipt for what he put on it.
If he THINKS its a GM crate engine in, then there are a wide variable of ranges of what is actually on it. Also you really need to know your camshaft timing to really judge what CR is good and what is too much for safe street operation on pump gas.
You'd be better off pulling the heads (like the others stated), verify the components & then consider shaving the heads for your CR increase. Holley website or tech support should be able to tell you max amount that can be safely removed from the head. You can then decide on the proper head gasket, which will provide the proper amount of quench.
If you do end up needing to get the compression up, Milling the heads .025 is best, next best is use the Fel. #1094. Both surfaces must be flat to use that gasket, and no adhesive.
