68 vapor locking?
Old Aug 14, 2007 | 03:24 PM
bigm789's Avatar
bigm789
3rd Gear
Default 68 vapor locking?
anyone had a problem with 68's vapor locking?
Old Aug 14, 2007 | 03:51 PM
bashcraft's Avatar
bashcraft
Are you sure it's vapor locking? What are the symptons?
Old Aug 14, 2007 | 09:07 PM
Ron R's Avatar
Ron R
Eight or nine years ago I was having that problem on my 68 (427) - the shop ran new fuel lines and that solved the problem, if I recall the problem was the return line.
Old Aug 15, 2007 | 10:16 AM
sxr6's Avatar
sxr6
I had serious vapor lock problems till two weeks ago.
You can try insulating the lines & fuel pump but the most realiable cure I was advised is a cheap electric fuel pump back at the tank.
My problem is no more
Old Aug 16, 2007 | 10:04 AM
bigm789's Avatar
bigm789
3rd Gear
hello. the car had been missing a little when you got on it (not real hard). we had been driving it for oh, about half an hour 45 mins and it started missing worse. i would stop and it would get REAL doggy on take off. i got to thinking this isn't good so i tried not to stop at all and get it home. as i was pulling into the parking lot it about died. i let it sit for abour 10-15 mins, started up took off and it did fine... what do you think? thanks for responding by the way!
Old Aug 16, 2007 | 10:43 AM
Ron R's Avatar
Ron R
What was the temperature when it shut down? What you describe could also be a little bit of water in the gas, vapor lock only happens when it's hot enough to evaporate the fuel in the lines.
Old Aug 17, 2007 | 02:20 PM
bigm789's Avatar
bigm789
3rd Gear
well the temp guage wasn't really reading hot. it was warm inside the car. it does have the side exaust if that makes a difference.. a can of seafoam wouldn't hurt anything would it?
To 68 vapor locking?
