still having trouble starting first time
Old Aug 14, 2007 | 04:32 PM
smon's Avatar
smon
Default still having trouble starting first time
i posted a while back about a new cam and that i couldnt get it to start.
http://forums.corvetteforum.com/show....php?t=1779378
i took everthing apart. here is tdc and i got a new sprocket so i can see the timing marks. i have another crank gear on there so the timing mark shows better for the pic. but it still wont start. i loosened the valves to make sure they werent too tight but still nothing. the distributor points towards number one cylinder but i still get gas shooting back up through the carb.
Old Aug 14, 2007 | 04:55 PM
SIXFOOTER's Avatar
SIXFOOTER
With it set up like the pic shows that has the #1 at TDC, if you put the distributor in with the rotor pointed at the #1 plug wore on the dist cap, it should start if you have the fireing order set to 18436572
Old Aug 14, 2007 | 05:16 PM
Vette Crazzy's Avatar
Vette Crazzy
with the cam gear dot at 6 oclock and the crank gear at 12 oclock. that is top dead center for cylinder #6... pop your dist out and turn the rotor 180 deg to point at #6 cylinder on the cap. it will fire right up!
vc
Old Aug 14, 2007 | 05:19 PM
smon's Avatar
smon
with the timing marks lined up shouldnt number 1 cylinder be at TDC on the compression stroke...meaning that the distributor should be pointing at number 1 spark plug?
Old Aug 14, 2007 | 05:25 PM
dannyman's Avatar
dannyman
vc
12 o'clock on both gears would be #1 TDC
Old Aug 14, 2007 | 05:32 PM
Vette Crazzy
NOPE
Old Aug 14, 2007 | 05:33 PM
Vette Crazzy
EXACTAMUNDO LOL
Old Aug 14, 2007 | 07:49 PM
smon's Avatar
smon
i flipped the distributor 180 and now it seems good
it almost fired up but not enough to run completely kinda sputters out after i release the key.
i think its just the valves now, i have a guy coming over to help me with that.
thanks for all the help, if you have any other suggestions i would appreciate it.
sean
Old Aug 14, 2007 | 11:10 PM
dgruenke's Avatar
dgruenke
Does it run better if you turn the distributor body all the way to one side?
Old Aug 15, 2007 | 12:27 AM
LB66383's Avatar
LB66383
Turn the distributor counterclockwise in small increments and see if it starts and stays running. Sounds like the timing is too retarded right now.
Old Aug 15, 2007 | 08:14 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
sean
now try this, with the timing mark at 10* BTDC set the distributor at the #1 position
Old Aug 15, 2007 | 05:18 PM
smon's Avatar
smon
finally got it started, thanks for all the help. i broke in the cam just now but had some overheating problems and some coolant overflowed and burnt a hole in my overflow tank.
how was i supposed to keep from overheating without moving and breaking in the cam?
Old Aug 15, 2007 | 05:28 PM
dgruenke's Avatar
dgruenke
Congratulations.
You can help with the overheating by filling the coolant at the thermostat housing, making sure that it stays full, and by putting a fan facing the radiator.
Old Aug 16, 2007 | 06:50 AM
aworks's Avatar
aworks
vc
Old Aug 16, 2007 | 01:52 PM
69vettester's Avatar
69vettester
With your gears installed like that, (BTW thats how most Vendors recomend). Just find TDC on the #1 piston, install your Dist. Correctly , point the rotor to #1 cyl, Maybe move the dist. counter clock wise a little to give it some advance, and it should fire right up, without Backfiring through the carb. Time it from there...New Performance heads and valve train usually turn the Headers red hot for a minute as it initially breaks in. Thats why the oil needs changing after the first 30min. breakin.
Old Aug 16, 2007 | 02:30 PM
68/70Vette's Avatar
68/70Vette
When I was adjusting my distributor to point to #1, I took an unused HEI distributor cap and cut a hole in it just below the terminal I was going to use for number 1. I rotated the front damper counterclockwise for the correct Before Top Dead Center advance and then adjusted the distributor so that the rotor was exactly under number 1. Then I replaced my "holed" cap with a new HEI distributor cap.
To cut the hole, I used a Dremel tool with a metal cut off disk. It worked perfect on the plastic. It basically just melted the cut lines into the plastic.
Old Aug 16, 2007 | 02:36 PM
billla's Avatar
billla
St. Jude Donor '14
Dude, that's awesome!
#6 and #1 are companion cylinders; both are at TDC at the same time on opposite strokes (compression/exhaust) IMHO, I always take a minute to set it with reference to #1 - but #6 works as well if you don't want to turn it over.
The comment about 10 degrees advanced is right on - this really helps with starting; too many people try to start 'em set to 0 degrees.
The overheating is definitely a concern - did you add coolant during the startup? The engine will suck quite a bit of coolant as it fills; generally I recommend doing the initial fill with just water, and leaving the radiator cap off to allow you top it up right after startup.
So is everything going well now?
To still having trouble starting first time
Old Aug 16, 2007 | 05:05 PM
smon's Avatar
smon
yeah i broke in the cam yesterday and it runs ok. the idle is rough but im taking it to get it timed and the valves checked today.
do i need to change the oil and filter now or can i drive it over to the shop?
Old Aug 16, 2007 | 05:19 PM
billla's Avatar
billla
St. Jude Donor '14
Cool Rough idle could be a vacuum leak, but sounds like you're on the right track. You'd be fine to drive it over...but I always change the oil & filter right after break-in. I've cut a couple of post-break-in filters apart, and they're generally pretty nasty with gunk.
Old Aug 16, 2007 | 06:49 PM
smon's Avatar
smon
k ill change that oil befor anything.
im getting quite a bit of smoke coming out of the breather and its coming inside.
will this clear up after a while and what causes this?
thanks for answering all my questions.
sean
