Stuck bleeder
Old Aug 16, 2007 | 09:51 AM
gorrie16's Avatar
gorrie16
Default Stuck bleeder
This is not corvette related but last night I was changing the brakes in the little lady's car and I went to bleed the brakes but couldnt move the bleeder. I soaked with wd-40 a few times too. Any ideas of what I can do to move this thing? Thanks
Don
Old Aug 16, 2007 | 10:43 AM
chevy69's Avatar
chevy69
St. Jude Donor '08
Try PB blaster - better than WD 40 for corrosion. Can you get a 6 pt socket on it?
Old Aug 16, 2007 | 10:51 AM
SIXFOOTER's Avatar
SIXFOOTER
I like a 6 pt box end wrench for that myself, Can see it fit a bit better. PB Blaster is better than WD40, maybe use a little heat, but don't get nuts with it
Old Aug 16, 2007 | 10:54 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If the above ideas don't get it, put a vice-grip on it very tightly and give it a smack with a heavy hammer. I know it's not your car, but I now use stainless bleeders and no longer have such problems. Good luck.
Old Aug 16, 2007 | 01:34 PM
77BuffaloVet's Avatar
77BuffaloVet
PB Blaster...Let it sit for a while.
The bleeder will only snap if you torque it at an angle.
I usually use an open end wrench so I know it is stright on and then give it a few very easy wacks with a very small hammer.
Be patient.
Good Luck!!!
Old Aug 16, 2007 | 03:55 PM
dgruenke's Avatar
dgruenke
After you put the PB or WD-40 on it, tap the area around the bleeder with a small hammer to try to jar it loose. It doesn't take much, but sometimes it can get the seized part to jar loose.
Old Aug 16, 2007 | 08:00 PM
sly vette's Avatar
sly vette
Carefull application of heat IMHO. After a good soak in PB Blaster
To Stuck bleeder
