no power to a/c compressor
Old Aug 16, 2007 | 07:12 PM
PKB's Avatar
PKB
Cruising
Default no power to a/c compressor
I have no power to the a/c compressor on my 1982 vette. anyone know where to start?
Old Aug 16, 2007 | 07:45 PM
sly vette's Avatar
sly vette
Start with the thermal limit fuse. It should be sitting near the compressor. Black plastic and square.
Old Aug 16, 2007 | 11:54 PM
DARROW's Avatar
DARROW
if you are low on freon you have a auto presssure shut off. should be by the compressor.
Old Aug 17, 2007 | 01:37 PM
Vette-4-Life's Avatar
Vette-4-Life
The low pressure switch will be in the line leading to the drier (sits directly above drier). You can bypass this and with the car off turn on the AC. You should hear the clutch kick in if wiring/fuses are good.
To no power to a/c compressor
