Cold Starting Problem
Old Aug 16, 2007 | 09:23 PM
Boston!'s Avatar
Boston!
Default Cold Starting Problem
I'm a carb idiot, is what I'm finding out. I'm using the original QuadraJet that came on my '72 sbc, and I've rebuilt it using Lars' carb paper and adjusted it as best I could per that paper, the Chevy service manual, and the info in the timing sticky. I can't get it to start without pumping the gas and then feathering it until it warms up. I feel like I have a choke problem, but I'm not sure. The service manual says to hold the choke rod all the way down and then bend it until it fits in the groove on the bottom of the arm, but I had to bend the hell out of it to get it there- doesn't seem right. Here's two pics:
The rust is from dipping everything in the conditioner during the rebuild, but appears superficial. I've moved the vacuum line that goes to the choke actuator from the bottom front port to the upper front port, because it seemed to make the car idle better. It doesn't affect this problem from what I can tell.
Here's a video of a cold start without touching the throttle. This was after I'd started it once earlier, so I didn't have to pump the throttle to get it to start, at least. Normally I do if it's been sitting overnight: VIDEO
Ideas?
-=Boston!=-
Old Aug 16, 2007 | 11:03 PM
sly vette's Avatar
sly vette
tHE BEND IN THE CHOKE ROD LOOKS TO BE EXCESSIVE. aND IT MAY BE RUBBING ON THE HOUSING FROM WHAT i CAN TELL.
Damn cap lock!!!
In the pic is the Eng cold? you stated that you had it running earlier in the day.
You will always have to depress the gas pedal to re-set the choke, and allow the accelerator pump give it a shot of fuel.
I don't think you are far off. Just an adjustment of the choke and choke pull off. And look in the carb with the throttle plate open and see if you are getting a shot down the carb when throttle is depressed.
Good Luck!
Old Aug 17, 2007 | 05:25 AM
Boston!'s Avatar
Boston!
The engine is cold in the video. I started it to get it out of the garage earlier but only for about 20 seconds. I get the impression this isn't worth a reply for most... tell me where to start! There's a lot of knowledge to absorb for a newbie. Basic tuning info I should be reading, maybe?
-=Boston!=-
Old Aug 17, 2007 | 08:06 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Here's yours
this is my 68 327 right after i got to work this AM
the first thing I notice is your choke stove is missing the littel snap lock, whick fixes the position of the rod on the choke lever, with out this, you rod can move independantly form teh choke. second thing is that the bending is exxcessive, and seems to be turned 90 degrees from mine, but that is doe to the different manifolds
hmmm
also looks like the pin that sets the fast Idle cam on your secondairies is bent too
hmmmm
in looking at your video, I wouls hazard to say the divorced choke is at the root cause of your troubles, are you sure its the right one for your intake?
hmmmmm
To Cold Starting Problem
