rear end
Old Aug 17, 2007 | 07:58 AM
glo's Avatar
glo
Default rear end
How can I tell what gear size I have in 77 corvette doing a rebulid with about 320-350 hp just wondering if I should change gears this is mostly for street I already have trailing arm ,spring out just thinking with everything out if I need to do anything with the rear end
Old Aug 17, 2007 | 08:01 AM
bluesilver82's Avatar
bluesilver82
I am about to swap to a 3;73 in my 82 my stock is 2.72 yours is probably 3.03 or something like that.
Old Aug 17, 2007 | 08:14 AM
BB68Vett's Avatar
BB68Vett
Turn the halfshafts one full revolution and count how many times the driveshaft rotates. This is your ratio.
Old Aug 17, 2007 | 08:15 AM
Mikes*Corvettes's Avatar
Mikes*Corvettes
Axle codes are stamped on the bottom of the differential carrier housing just forward of the cover,check your code against these codes for the 76/77 model
OA 3.08:1
OD 3.36:1
LR 3.36:1
OB 3.55:1
OC 3.70:1
Old Aug 17, 2007 | 08:16 AM
Gordonm's Avatar
Gordonm
It will be a 3.08, 3.36,3.55,3.73 or possibly 4.11. Take your axle coming out of the rear and spin it exactly ONE revolution and count the number of times the driveshaft goes around. 3 1/4 times you have a 3.36, 3 1/2 times a 3.55 and so on. If the halfshafts and tires are still on just rotate the tire exactly ONE revolution and count the driveshaft revs.
Old Sep 20, 2007 | 11:43 AM
HUSKER-Z's Avatar
HUSKER-Z
I have a 3:08 in right now. What would be the difference in going up a level or two? Mechanic said 4:11 wouldn't be a good daily driver??
Old Sep 20, 2007 | 12:24 PM
Scott Marzahl's Avatar
Scott Marzahl
For a stock L-48, I think a 3.36 would be a good upgrade. If it was a warmed over 350, I might consider a 3.55, it just depends on how often you drive the car.
Old Sep 21, 2007 | 02:58 PM
HUSKER-Z's Avatar
HUSKER-Z
Went w/ a 3:55 from Ikerds (sponser on here). Time will tell, once it gets here and is installed! thanks for all your help S!
David
Old Sep 21, 2007 | 08:34 PM
72LS1Vette's Avatar
72LS1Vette
As long as you have everything apart, take off the diff cover and take a good look at the internals. If everything is good it will only cost you a gasket, and the fluid probably needs to be changed anyway. If there is excessive play in the yolks (more than 1/16" or so - opinions differ) or the ends of the yolks are mushroomed you will need to do a rebuild. If a rebuild is needed you can decide on what gears you want to use.
Rick B.
Old Sep 21, 2007 | 11:26 PM
sly vette's Avatar
sly vette
I'm not much for just posting icons but here goes
Old Sep 23, 2007 | 01:24 PM
JustinD's Avatar
JustinD
I put 4.10's in and it is a little much esp with a 3 speed auto. Although it is crazy off the line.
Old Oct 2, 2007 | 09:35 PM
SUPERPOWERS's Avatar
SUPERPOWERS
Damn, 2.72 that sucks. I also have an 82 and I am running a T56 6speed. I am going to put in 4.10's. Do you know what rearend is on our cars? I heard somewhere that they were Dana 38's. Also which carrier is in there? Did you need to change the carrier for the new gears?
thanks,
Josh
To rear end
