Dyno day for me...
221.9 RWHP... I suppose it's not bad, but a guy always wants it to be about 5,613,617,317,387.81
350, roller cam (I lost the damn cam specs), roller rockers, flat tops, Dart Iron eagle platinum heads (64 CC, 2.02 intake, 1.6 ex), Holley 650 spread bore, dual plane intake, ram horns, 2" pipes - no cats, 4 speed....
click to enlarge.
I found the torque curve (or lack of) interesting, and good imo..
this is off teh second run which was a little less than the first, but nearly the same.
what do ya'll think?
If you figure around 260HP at the flywheel I'm not sure it's WAY off if it's a mild cam and 8.5 CR or so...
MotorHead, what are you thinking the combo should see?
what do ya'll think?[/QUOTE]
Did they do air:Fuel ratios during the run? Those would help. looks like you're losing power in the lower range...right where you'd feel it in the seat gage!
It also looks like there's still more to be had at 5500 rpm. getting close but the curve is still climbing. why'd you stop early?
Last edited by TheMongoose; Aug 17, 2007 at 06:36 PM. Reason: thought of something else to say
the car does run pretty decently....
and yes, the exhaust does suck the big one...
i expected more, the car runs excellent, starts perfectly. I know my timing and shet are right...
Find a dyno that works myfriend. Someone don't know how to run to run a dyno or has a bad one as those graphs and number are worthless.
Sorry for the bad news but maybe you really have more power. My quess u should have 300hp & ft-lbs at the wheels.
cardo0
cardo0
That would be hard to take...
cardo0
Again HP = (torque x rpm)/5252. Thats it.
The engine torque may vary at different rpm and may not increase at a linear rate. But the truth is that at every rpm the HP is = (torque x rpm)/5252 and should be plotted as so. If u cannot understand that i cannot help you. HP is only a mathmatical relationship to torque at a specific rpm - lets not make it confusing like HP is some escoteric knowlege. Just do the math.cardo0
