c3 lower ball joints
Old Aug 17, 2007 | 06:05 PM
troythefixer's Avatar
troythefixer
Default c3 lower ball joints
I asked for some advice a while back on lower ball joints for the c3. Just for the record the new jc whitney tools are just like the old ones. i ordered the H tool for ball joints and broke it the first time i used it.
Troy
Old Aug 17, 2007 | 08:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Weird. I have the identical tool from Harbor Freight, and it's never failed me.
Old Aug 17, 2007 | 09:02 PM
72LS1Vette's Avatar
72LS1Vette
I used a tool called a sledge hammer to get my lower ball joints to seperate. You should have the lower control arm off the car to use it, but it only took a couple of hits to get both spindles free. My pickle fork was useless.
Rick B.
Old Aug 17, 2007 | 09:20 PM
...Roger...'s Avatar
...Roger...
Put your jackstand under the lower arm out close to the joint.Let the weight of the car down.Loosen lower joint nut but leave on the last few threads.The weight of the rotor and brake caliper will now be on the lower joint stud.Take your hammer and hit the side of the spindle right where the joint stud goes through spindle.It will pop and drop down against the joint nut.
Old Aug 17, 2007 | 09:28 PM
SIXFOOTER's Avatar
SIXFOOTER
Yep, thats how I do it, but I hold annother hammer on one side of the spindle and smak the other side, once or twice ant they come apart everytime
Old Aug 17, 2007 | 09:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That trick has never worked for me.
Old Aug 17, 2007 | 09:49 PM
...Roger...
You might not be getting your stand or jack out far enough on the arm.If the snubber under the UPPER arm is hitting and keeping it from dropping and putting the weight of the rotor and caliper on the lower joint stud then it wont work.
Old Aug 17, 2007 | 09:52 PM
SIXFOOTER's Avatar
SIXFOOTER
Put the jackstand under the outside of the lower shock cup
Old Aug 17, 2007 | 11:06 PM
troythefixer
tks for the input i'll try that tomorrow. Troy
Old Aug 18, 2007 | 01:18 AM
Sharkboy's Avatar
Sharkboy
Default Everybody stand back...
Upper ball joints were no problem. The lowers are still in the control arms and have been a PITA. All of the control arms are now out of the car. I have already been through the sledge hammer and pickle fork route and was surprised at their resistance to my manly ways.
Tomorrow I am using a tool called a bazooka. (Actually, I've got a small press that should handle the job.)
Curt
Old Aug 18, 2007 | 07:52 AM
captainmorgan's Avatar
captainmorgan
This is how I did mine but they were stubborn. I had to go get a 4# hammer. I hit it a few times with the 4# and it popped off.
To c3 lower ball joints
