Last caliper, last bleeder...too rusty...too much force...snap
Tried the bolt extractor already. Did not budge.
Drilled it to 7/32 (still smaller than threads). What size should the hole be for stock size bleeder?
What is the bleeder size tap?
Can I just drill and tap to next size bleeder? What size would that be?
Thanks guys.
If you haven't damaged the threads, what you can do is work a tap of the proper size, (as said pull one of the other bleeders) and slowly work the tap in a little at a time..each time you turn it say a half turn back it completely out and try to pick the excess metal out with a sharp pick..( an old test light is god for this) a little time consuming but the best way
I put the caliper in a vise and drilled the bleeder out using a slightly larger bit each time, until using a bit just about into the threaded area. Then used a tap to get the rest of the metal out, as stated above.
It just occured to me that what if I drilled the hole too deep? I drilled until I could see the bit just touching the stainless steel sleeve in the piston.
Does a bleeder bottom out on casting or could it be a blind hole?
